Greetings-New member with turn signal/headlight issue
Old Dec 14, 2012 | 11:54 PM
bayou1's Avatar
Smile Greetings-New member with turn signal/headlight issue
Hello all from Chicago, so excited to communicate with other jag lovers.
As of today, my 2000 XJ8L headlights cut off whenever i use the left or right turn signal, and may or may not cut back on after cutting off turn signal. I can get them back on with a slight toggle when turn signal is off. Any wisdom rained upon me would be greatly appreciated.
Old Dec 15, 2012 | 03:00 AM
Welcome to the forum bayou1,
Hopefully this turns out to be an issue with the Steering Column Multifunction Switch wiring and not the switch itself.
Follow this link XJ ( X308 ) XJ8 / XJR - Jaguar Forums - Jaguar Enthusiasts Forum to the X308 section for help, advice and information.
Remember to add vehicle details to your Signature to help others to give relevant advice. Go to the User CP button on the left of the top menu bar, then Settings & Options under Your Control Panel. Select Edit Signature and enter the details.
You can also visit the US Mid West Region section by following this link https://www.jaguarforums.com/forum/mid-west-us-il-ia-mi-mn-mo-oh-wi-39/ to find other members in your region.
Old Dec 15, 2012 | 10:26 AM
Old Dec 15, 2012 | 02:18 PM
bayou1's Avatar
Thanks for advice, was wondering if checking the wiring associated with turn signal was a simple task, i dont have very much experience in the electrical aspect of the car, but i am very much mechanically inclined.
Old Dec 15, 2012 | 02:59 PM
You'll need the XJ Series 2000 Electrical Guide and the Service Manual (JTIS) extract on removing the Multifunction Switch.
You can download these from my MediaFire account by following these links:
XJ Series 2000 - Electrical Guide.pdf
JTIS - XJ8 - 2000 - Steering Column Multifunction Switch.pdf
The relevant section in the Electrical Guide is 09 (Exterior Lighting).
Old Dec 15, 2012 | 06:44 PM
MidwestJag's Avatar
Greetings bayou1, and a hearty welcome from the Midwest Region of the forum. Lots of folks around here from Chicagoland! Best of luck getting your problem sorted out. Enjoy the ride!
Scott
Old Dec 16, 2012 | 02:13 AM
bayou1's Avatar
Thanks for the info G3, gonna sluth this as soon as I get a chance.
Old Dec 16, 2012 | 03:46 AM
Whenever you're working around the the driver's airbag, follow the recommended Jaguar safety procedures to discharge the backup capacitors.
If in any doubt about how to do this, ask the question on X308 section.
Old Dec 17, 2012 | 11:35 AM
Hey welcome aboard....... good to have you here with us here at Jaguarforums
JarodL
Mar 7, 2024 01:39 AM
Raul Lara
Sep 14, 2015 07:31 PM
laserguy
Sep 3, 2015 02:02 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
