hi
Old Jul 17, 2014 | 04:50 AM
rally's Avatar
Default hi
quick intro on my self. I own a Jaguar S-type v6 2001 model which is currently in limp mode and trying to find answers online to get it working again would highly appreciate your help and suggestion on the same.
kindest regards
Rally
Old Jul 17, 2014 | 04:53 AM
Welcome to the forum Rally,
You are going to have to get a scantool on your S-Type to read the error codes. Without those it's guesswork and speculation.
Follow this link S-Type / S type R Supercharged V8 - Jaguar Forums - Jaguar Enthusiasts Forum to the S-Type forum for help, advice and information.
You can also visit the Other Areas Region forum by following this link Other Areas - Jaguar Forums - Jaguar Enthusiasts Forum
Enjoy the forums.
Old Jul 17, 2014 | 05:47 AM
welcome to the forum - you will find plenty of info and support here simply follow the links Graham has provided and enjoy!!
Old Jul 17, 2014 | 09:32 AM
Welcome to Jaguar Forums Rally,
Old Jul 17, 2014 | 03:52 PM
o1xjr's Avatar
Old Jul 17, 2014 | 07:11 PM
Bad Cattitude's Avatar
Welcome!
Old Jul 17, 2014 | 07:30 PM
Hello, Rally,
Someone will be along shortly, if they haven't already, to direct you to the correct section where you can fine help.
Old Jul 18, 2014 | 08:32 AM
rally's Avatar
thankx for a warm welcome and instructions for the forum, just a quick reference to the problem I'm having with my car.
my jag s-type 2001 3L v6 model is in limp mode after I was fiddling with the main fuse box trying to get the air-conditioning started.
after starting the car the vehicle goes into Engine Fail Safe mode with the following errors
P1000 System check on completed since last memory cleared.
P1574 Throttle position sensor disagreement between sensor
P1576 Accelerator pedal position unavailable.
P1577 pedal position sensor disagreement between sensor.
I have changed the accelerator pedal and the throttle body which I have bought from E bay second hand.
the errors are still the same. please advise as I cant afford the dealer workshop for repairs.
Old Jul 24, 2014 | 11:11 AM
Helpful_information
