Jaguar Xtype 2006 2L D
Old Apr 14, 2020 | 11:32 AM
Geordie65's Avatar
Default Jaguar Xtype 2006 2L D
Hi, i bought my Jaguar last last September 2019. After about 6 weeks i had a problem wher the engine suddenly cut out, no power steering etc. I took it back to the garage who changed the fuel pump. Everything was fine until the szme thing happened in March. I have had the fuel line and the fuel pump changed (both second hand) and it is still has the same problem. Is it the ECU.? Help please. Dave
Old Apr 14, 2020 | 03:34 PM
Daf11e's Avatar
Welcome aboard Dave.
Old Apr 14, 2020 | 03:49 PM
o1xjr's Avatar
Welcome to the forums.
Old Apr 14, 2020 | 10:09 PM
Welcome to the Forums.
Not a lot of Info there on which Jag you have??
That Info will help us all to help you.
Old Apr 14, 2020 | 10:56 PM
Hello, Dave,
Old Apr 15, 2020 | 01:35 AM
Geordie65's Avatar
Default Jaguar xtype
Hi, it's an Xtype 2006 2.oL estate. Not sure what else I can tell you. Dave
Old Apr 15, 2020 | 02:53 AM
Welcome to the forums Dave,
An unusual question from Grant. He must have read your question but skipped the title!
You need to get a code reader/scantool on it. Mysterious cut outs, apart from being potentially dangerous, are very likely to leave some error codes which would help troubleshoot the issue. ECM faults are not unknown but fortunately rare.
Follow this link https://www.jaguarforums.com/forum/x-type-x400-14/ to the X-Type forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues. You can also use the UK & Eire Region forum by following this link https://www.jaguarforums.com/forum/uk-eire-68/ to find other members in your region.
I've added vehicle details to your Signature to help others to give relevant advice. If you want to change these, go to the User CP button on the left of the top menu bar, then Settings & Options under Your Control Panel. Select Edit Signature and enter the details.
Enjoy the forums.
Old Apr 15, 2020 | 03:12 AM
Geordie65's Avatar
Enjoy the forums.
Hi Graham, thank you for your reply. Here is the message from my mechanic. After removing and refitting the ecu, it fired up briefly to cut out again. Code is throttle pedal track c stiu. Its not the rail, the pump, or the pedal. So logic, only logic tells me its the ecu.
Does anyone know which number on the ecu i need to match to replace. Thanks in advance. Dave
Old Apr 15, 2020 | 06:00 AM
Dave,
Is your mechanic using the Jaguar DTC lookup table or running diagnostics with Jaguar SDD (Symptom Driven Diagnostics)? Jaguars can give strange results on generic scantools and online error code lookups are often very misleading.
Removing/refitting the ECM is effectively a "hard reset" which puts fuel trims etc back to default settings. After starting, the ECM will immediately start adapting to inputs from other sensors and that explains the cutting out again.
I suggest you take the question to X-Type forum (https://www.jaguarforums.com/forum/x-type-x400-14/) for advice from members with the same model. As you can see from this JEPC (Jaguar Electronic Parts Catalogue) extract, there are a lot of ECM changes on the X-Type with VIN range. They may be backwards compatible but it's unlikely to be a simple "plug&play" substitution.
Old Apr 15, 2020 | 07:12 AM
welcome to the forum
Old Apr 15, 2020 | 08:58 AM
Welcome to Jaguar Forums Dave,
Crinkle60
May 6, 2018 09:23 AM
2000jags
Dec 25, 2017 10:32 AM
tazman
Jun 16, 2017 02:08 AM
phyllisita
Aug 28, 2013 07:15 PM
Mlb
Mar 24, 2013 08:32 PM
