My first jag
Hi folks
I'm LaMarr. I recently purchased a 2015 jaguar xf here in sacramento. No problems at all until alternator needed replacement. Since replacement car starts and runs. When you attempt moving, steering wheel will shimmy. Diagnosis showed no issues yet the computer will not recognize the new alternator
Welcome to the Forums.
Sounds odd, but it is what it is.
Members in the XF Tech Section may have answers.
Your Year Model is at a change point, X250 or X260, and 2015 Build Date is the key.
Good luck.
Good luck.
I'll find it and get back to you. It's just so odd - I mean the car runs fine until you put it in gear. Diagnostic found nothing. My guy is a general mechanic and was the end of his knowledge. He says take it to jaguar and have them reset the computer so it recognizes the new alternator and begins charging the battery. I ove the car, that said, had I known this l wouldn't have bought it.
As Grant has remarked, the two XF models are very different.
The alternator should be a straightforward replacement on either the early (2007 - 2015) or current (2015 onwards) XF. However, you are likely to have had a discharged battery as a result of the failure and this could require a BMS (Battery Monitoring System) reset on the current X260 model. This is a dealer level diagnostics task but I'd first fully charge the battery (off the vehicle) and give it another go.
Enjoy the forums.
Welcome to Jaguar Forums LaMarr,
I mean to sy the car runs. I'm not driving because codes won't clear. 225.00 to depress a reset button? Come on, man.
Not sure if I'm conflating different issues and possibly exacerbating a minor problem. The car starts normally, in park, it sounds as good as when I bought it. Put it in gear and it doesn't recognize the alternator change. Message to park immediately.
Hi folks
Visiting jaguar usa I found that the navigation systems are updated/reset via DVD and even over Wi-Fi. I know it in my heart that's also the "secret sauce " they have that sadly, I do not. Can you verify that "such is the case"?
WTB[NorthEast]: Brown Jaguar XF steering wheel wanted.
Dayzel108
Apr 5, 2014 12:52 AM
