new to jags (starting problem)
recently became recommitted to my 98 vdp, had the trans replaced recently then let it sit for a while due to being involved in a motorcycle accident. now it only turns wont start, just cranks. Ifigured i would start knocking down problems replaced battery, starter, fuel pump, and started to replace the coil packs and spark plugs, but then did a compression test and it wasnt right. any advice?
I'm sorry to read about your motorcycle accident. Someone will be along shortly to direct you to the proper section where you can get help for your starting problem.
Do a seach on "cylinder wash" or "bore wash" and you might have the problem, as well as the solution.
If the case (and I hope so for you, as it is an easy fix), your cylinders lost compression due to the fuel spray taken away the oil layer between the piston and the cylinder.
Add some oil on each cylinder through the spark plug hole, and you should be good to go (read the various details on the "how to" in the search results, there are various threads on this issue).
Good luck,
Eric
Good luck,
Eric
Welcome to Jaguar Forums fattyblow,
I see you posted in the tech section so should be getting some help with your problem.
Welcome to the forum fattyblow,
I can see you've already found your way to the X308 tech forum so there's no need for a link to it from me. The 'HOW TO' thread at the top is a good place to start for info on regular issues.
Enjoy the forums.
Enjoy the forums.
search facility etc, can be found here within the following link Using JF "How To"
X_Type_South_Africa
Dec 9, 2015 05:37 PM
1964Daimler
Sep 2, 2015 11:41 PM
