Hello-
I've read through many posting about P0128 and have not been able to use advice to correct the issue I'm having so I'm hoping if I explain my symptoms it might help others help me.
2011 XKR 175
Issues- P0128 code keeps returning
Resolutions I've tried
Replaced the thermostat twice- OEM
Replaced Coolant temperature sensor twice
Replace Coolant using a vacuum system to ensure no air is in coolant system- Orange coolant
As of last week the new battery was dead and had to jump start car - I've not driven it in 2 weeks.
Speed controller A code popped up after jump started and tranny acted funny- gear box fault.
Temperature runs somewhere between 183 and 203 degrees and does go back an forth between the range
Reset MIL and drove for 2 hours but P0 128 still pending when checked with scanner along with Evap and EGR cycle not complete - therefore the Emission system is not cycled for car to pass Emission test yet
Is it typical for these cars to be in second gear from a dead stop? Used paddles to start out in first and shifted through gears without any issues
I have several Jags- 2 XJ and have a lot of mechanical training but this is boggling my knowledge and cannot resolve.
With check engine light coming on the car will not pass Emissions test.
Not much information posted on 2011 series issues - most has been for 4.2 liters engines.
Mine is a SC 5.0.
Please post advice and possible solutions. Thank you
2011 XKR 175
Mine is a SC 5.0.
close
- Join DateDec 2011
- LocationDurham, UK
Liked:17,003 Times in 12,221 Posts
Welcome to the forums skidman,
The New Member Area - Intro a MUST forum is for newbies to tell us something about themselves and their vehicle. It is not for complex technical discussion which should be posted in the relevant MODEL forum. Your question will be seen there by members with the same 5.0 model and is likely to receive more appropriate advice rather than just sympathy.
Follow this link https://www.jaguarforums.com/forum/xk-xkr-x150-33/ to the XK/XKR forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues. You can also use the US Midwest Region forum by following this link https://www.jaguarforums.com/forum/us-midwest-39/ to find other members in your region.
Enjoy the forums.
Enjoy the forums.
Graham-
Thank you for the information: with exception of signature I signed up on this forum in Sept.....
I've edited my signature as advised.
Thank you
Larry
Thank you
Larry
LnrB
close
- Join DateMar 2014
- LocationTehama County, California, USA
Liked:10,282 Times in 5,899 Posts
Hello,
I'm sorry your Jaguar isn't working correctly, I hope you can get to the bottom of all your issues.
Thank you ElinoB. Originally Posted by LnrB
Hello,I'm sorry your Jaguar isn't working correctly, I hope you can get to the bottom of all your issues.
sklimii
close
- Join DateApr 2012
- LocationSummerville, South Carolina
Liked:4,697 Times in 4,006 Posts
welcome to the forum - enjoy!!!!!!!!!!!!!
Daf11e
close
- Join DateMar 2015
- LocationDural, Northwest Sydney. Australia.
Liked:4,685 Times in 3,247 Posts
Welcome aboard Larry.
Grant Francis
close
- Join DateFeb 2010
- LocationAdelaide Stralia
Liked:11,260 Times in 7,433 Posts
Welcome to the Forums.
Norri
close
- Join DateOct 2007
- LocationPHX some of the time
Liked:6,647 Times in 5,783 Posts
Welcome to Jaguar Forums Larry,
