p0300 and p1314
Old Oct 14, 2013 | 09:17 PM
mikedobosz's Avatar
Default p0300 and p1314
Please help I'm lost and confused. Tired of throwing money for no reason
Old Oct 14, 2013 | 10:54 PM
Welcome to the forum mikedobosz,
You will find the tech section and some helpful members this way XJ X300 / XJR - Jaguar Forums - Jaguar Enthusiasts Forum
Your regional section is this way Southwest US - AZ TX NM OK - Jaguar Forums - Jaguar Enthusiasts Forum
Those are misfire codes so there should probably be more?
Old Oct 15, 2013 | 02:06 AM
Good to have you here with us at Jaguar forums.
Follow Norri's link to the X300 forum for help, advice and information.
Enjoy the forums.
Old Oct 15, 2013 | 07:27 AM
welcome to the forum - plenty of info and support here - just follow the links provided
Old Oct 15, 2013 | 12:36 PM
Muddydog's Avatar
Hope you get the answers you need.
Old Oct 16, 2013 | 03:28 AM
Hey there and welcome aboard....... good to have you here with us here at Jaguarforums
If you need any further help with the site, please just ask any moderator, veteran member and we'll be glad to assist.
search facility etc, can be found here within the following link Helpful_information
I've manually upgraded you to Full forum access so you can better view the site and all its features. Please Jump on in and enjoy the site........
See you in the forums....
Old Oct 18, 2013 | 07:48 PM
Cambo's Avatar
Not sure if you're coming back Mike, but here is something at least.
P0300
Random misfire detected Run engine steady > 2 minutes 2 Fuel contaminated
Fuel injector(s) blocked or leaking
Ignition secondary circuit breakdown(coils, spark plugs)
Fuel pressure low
Cylinder compression low
Broken valve spring(s)
CKPS circuit fault (CKPS DTCs also flagged)
Fuel injector(s) circuit fault(s)(Injector DTCs also flagged)
Ignition coil primary circuit fault(s)(Ignition coil DTCs also flagged)
P1314
Catalyst damage misfire detected cylinders 4, 5, 6 (B bank)
– Run engine steady > 2 minutes 1 ** Refer to P0300 possible causes
I would start with the coils, they seem to be a regular topic.
Markos
Aug 20, 2025 06:28 PM
Norri
19
Sep 28, 2015 08:43 AM
reb1999
Sep 26, 2015 08:41 AM
Jagged-X
Sep 24, 2015 05:08 PM
05Blkstr
33
Dec 19, 2011 10:30 AM
