Replacement ECU for Manual X300 required
Old Jul 30, 2014 | 10:40 AM
Martin Aultbea's Avatar
Default Replacement ECU for Manual X300 required
Hello All,
Can anybody advise where I could pick up a replacement ECU for a manual XJ6 (x300) 4.0L Sport, 1996 Plate?
I have had numerous problems with the car cutting out during running, and have replaced starting coils, the air flow meter, TDC sensor and cooling water temperature sensor. When attached to the diagnostics computer the fault code is showing for damaged ECU.
Any help would be appreciated, I'm on the verge of moving this car on which would be a minor tragedy as it is in good condition otherwise.
Old Jul 30, 2014 | 01:01 PM
Welcome to the forum Martin,
Reports of a failed ECM are rare on the forum. If you post the DTC's in the X300 forum, members with the same model may be able to come up with additional possibilties to eliminate before you finally condemn the ECU.
If you have already tried the specialist UK Jaguar breakers, a quick search turned up 10 X300 ECU's listed on ebay UK.
Follow this link XJ X300 / XJR - Jaguar Forums - Jaguar Enthusiasts Forum to the X300 forum for help, advice and information.
You can also visit the UK Region forum by following this link UK - Jaguar Forums - Jaguar Enthusiasts Forum
to find other members in this country.
Enjoy the forums.
Old Jul 30, 2014 | 02:39 PM
Hello, Martin,
Welcome from ElinorB.
Old Jul 30, 2014 | 06:10 PM
welcome to the forum, you will find plenty of info and support here simply follow the links Graham has provided and enjoy!!
Old Jul 31, 2014 | 09:48 AM
Welcome to Jaguar Forums Martin,
Old Jul 31, 2014 | 07:11 PM
Helpful_information
Robert1968
Jun 24, 2017 11:16 AM
Sprayall
Sep 3, 2015 07:49 PM
AlbBolivar
Sep 1, 2015 04:34 PM
SkinnyLard
Aug 30, 2015 07:26 PM
SkinnyLard
Aug 29, 2015 04:24 PM
