Transmission fault light.
Old May 11, 2020 | 08:23 PM
John Ragland's Avatar
Default Transmission fault light.
Hey guys I have a 98jaguar xj8 that stopped changing gear when I pulled off. It seems like it's always in 4th gear from take off and don't change anymore. Code p1747/ p1000
Old May 11, 2020 | 09:09 PM
Welcome to the Forums.
The members in the XJ8 (X308) Tech Section will have answers,a s this is a well discussed issue.
Transmission fluid changing at approx 50K miles (80K kms) is crucial to thiis trans staying alive.
Good luck.
Old May 12, 2020 | 12:52 AM
Daf11e's Avatar
Welcome aboard.
Old May 12, 2020 | 04:10 AM
Welcome to the forums John,
The P1000 indicates OnBoard Monitoring Tests have not been completed since the last code clear so there must be some additional detail to your issue .......
Follow this link https://www.jaguarforums.com/forum/xj-xj8-xjr-x308-27/ to the X308 forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues. You can also use the US Mid Atlantic Region forum by following this link https://www.jaguarforums.com/forum/us-mid-atlantic-65/ to find other members in your region.
Enjoy the forums.
Old May 12, 2020 | 06:58 AM
Old May 12, 2020 | 08:08 AM
Welcome to Jaguar Forums John,
Old May 12, 2020 | 05:14 PM
o1xjr's Avatar
Welcome to the forums.
Old May 12, 2020 | 09:34 PM
Enjoy the forums.
thanks Graham, I will try what you said
Old May 13, 2020 | 02:09 AM
John,
I didn't mean anything more by "additional detail" than code P1000 indicates the codes have been recently cleared so you have presumably already done some troubleshooting.
The problem you describe is a transmission in "limp home" mode where it stays in 4th gear and engine power is also limited by the ECM. Members in X308 forum will be able to help with possible causes.
Old May 13, 2020 | 08:56 AM
Hello, John,
Old Jan 13, 2021 | 08:10 PM
Djilla1$'s Avatar
Default Tramission
Thanks John i really appriciate you getting my question in the right place. I am going to take a look now.
Dustin818
Apr 30, 2020 05:26 PM
hambrightjason92
Mar 17, 2020 12:12 AM
Donaldmaclean81
Oct 16, 2019 06:56 AM
lepae
Apr 8, 2018 05:30 PM
William Wells
Jul 7, 2017 07:25 PM
