transnission
Old May 12, 2017 | 02:15 PM
cturner353's Avatar
Cool transnission
I have a 1985 Jaguar XJ and I recently moved and had it towed mind you on a flat bed.I was not there when the driver dropped it off mind you this model Jag has a tricky transmission driver had keys to move it off truck so I know that was not a problem however when I got home to move it to another location it would not go forward it goes in reverse and moves but not drive I am beginning to think he could not get it out of gear to get it off the truck so he pulled from under it without taking it out of gear. can you tell me what the problem could be because I do not wish to buy a transmission for this baby
Old May 12, 2017 | 02:46 PM
Welcome to the forum cturner353,
Follow this link https://www.jaguarforums.com/forum/x...s-i-ii-iii-16/ to the XJ6 & XJ12 Series I, II & III forum for help, advice and information.
The 'HOW TO' thread at the top is a good place to start for information on regular issues.
You can also visit the US Lower Atlantic Region forum by following this link https://www.jaguarforums.com/forum/usa-lower-atlantic-nc-sc-fl-ga-66/
Enjoy the forums.
Old May 12, 2017 | 05:50 PM
Daf11e's Avatar
Welcome aboard.
Old May 12, 2017 | 07:00 PM
Hello,
Will it move if you pull it down into 1/L?
If it moves in L besides R, then you have lunched a clutch pack.
This is because L and R are controlled by the Low/Reverse band which bypasses the clutch pack.
Old May 12, 2017 | 08:29 PM
Doug's Avatar
Tricky? How?
There's nothing inherently tricky about this model of transmission but if operating yours seems tricky it ight be related to the problem you are experiencing
I think what you mean to say is "........he could not get it out of Park...."
I guess that's a possibility but the tow truck driver would have to be very inexperienced. If we assume he DID drag it of the truck while the transmission was in "Park" then internal damage may well have occurred, probably to the parking pawl but lord knows what else.
More likely is a failure of the internal "clutch packs", as mentioned.
What's the history of the car prior to being towed?
First, though, have you checked the fluid level?
Old May 13, 2017 | 04:08 AM
Welcome.
I have nothing to add. The BW66 is a pretty simple transmission.
Old May 13, 2017 | 07:24 AM
o1xjr's Avatar
Welcome to the forum.
Old May 13, 2017 | 11:57 AM
Welcome to Jaguar Forums cturner353,
Old May 14, 2017 | 05:37 AM
welcome to the forum
