X Type engages in reverse and does not move
Old Nov 10, 2015 | 06:01 PM
Cgates's Avatar
Default X Type engages in reverse and does not move
My 2003 2.5 X Type seems to engage in reverse, takes up the slack in the joints. However it does not push or move backwards. All forward gears work properly. I drove it 250 mile home when I bought it. I tested the resistance values of the 9 solenoids and they are all within the acceptable range of resistance. I checked the reverse pressure (when in reverse). It fluctuates between 215 and 255 psi, which is normal, although the needle of the gauge fluctuates rapidly, like the speed of buzzing.
The interesting thing is that I can reproduce the same no-movement affect with the foreword gears simply by disconnecting the the main traction-control/ABS plug. It is an easy thing to do because it is one big connector up front on top of the passenger side of the engine. When I do this, it creates the same affect as the reverse problem; joins tighten up, seems to be engaged but does not push/move the vehicle. Therefore, I wonder if my problem of reverse is a function of transmission management/control, not an internal transmission malfunction. What do you think? Cracked piston? This thing has only 50,100 miles on it.
Old Nov 10, 2015 | 06:42 PM
Welcome to the forum Cgates,
I've copied your post to X-Type forum for advice from members with the same model. Here's the direct link to it:
https://www.jaguarforums.com/forum/x...t-move-153081/
Follow this link https://www.jaguarforums.com/forum/x-type-x400-14/ to the main X-Type forum for help, advice and information.
You can also visit the USA North East Region forum by following this link USA North East - ME NH VT MA RI CT NJ NY PA - Jaguar Forums - Jaguar Enthusiasts Forum
Enjoy the forums.
Old Nov 10, 2015 | 07:08 PM
Welcome.
Old Nov 10, 2015 | 08:28 PM
Daf11e's Avatar
Welcome aboard.
Old Nov 11, 2015 | 03:43 AM
o1xjr's Avatar
Old Nov 11, 2015 | 05:42 AM
Welcome to Jaguar Forums Cgates,
Old Nov 11, 2015 | 07:21 AM
welcome to the forum
Old Nov 13, 2015 | 10:32 AM
Using JF "How To"
SD96XJ6L
Jan 19, 2016 05:34 PM
Scottish Chap
Nov 22, 2015 07:19 AM
scarbro2011
Oct 25, 2015 08:09 PM
nlt624
Oct 20, 2015 11:48 AM
JimC64
Oct 13, 2015 07:08 PM
