XF luxury premium 2010
Old Mar 12, 2018 | 05:55 AM
tootie's Avatar
Default XF luxury premium 2010
Hi all, Martin here from the west midlands uk,
I changed the battery in my smart key after seeing "smart key battery low" on the dash, i put the correct battery in and now it will not even open the doors, can anyone give a clue how to fix this problem or do i need to have the smart keys re mapped >
Thank you, Martin O'Toole.
Old Mar 12, 2018 | 06:16 AM
Welcome to the forum Martin,
There's not much to go wrong with a battery replacement other than ensuring it's fitted +ve downwards. A duff CR2032 battery isn't unknown. Does the other Smartkey work?
Follow this link XJ XJ8 / XJR ( X308 ) - Jaguar Forums - Jaguar Enthusiasts Forum to the X250 forum for help, advice and information
You can also visit the UK & Eire Region forum by following this link https://www.jaguarforums.com/forum/uk-eire-68/
Enjoy the forums.
Old Mar 12, 2018 | 06:31 AM
Welcome to the Forums.
Old Mar 12, 2018 | 06:54 AM
Old Mar 12, 2018 | 07:29 AM
rhomanski's Avatar
Welcome to the forums.
Enjoy the drive.
Old Mar 12, 2018 | 08:14 AM
tootie's Avatar
Thank's for your reply
As i had 2 new batteries, i replaced them both and to my horror, they both are now not working
Old Mar 12, 2018 | 09:23 AM
Ouch!
You must be able to open the car with the emergency key blade.
When you dock the Smartkey do you get SMART KEY NOT FOUND, PLEASE INSERT IN SLOT message or does the car start?
Old Mar 12, 2018 | 10:02 AM
tootie's Avatar
Default jaguar luxury premium 2010
Hi Graham
I can access the car with the key blade and start it when the smart key is docked but the screen still says "smart key battery low", i cannot open or close the car with the smart key.
Thanks, Martin.
Old Mar 12, 2018 | 10:07 AM
Hello, Martin,
Old Mar 12, 2018 | 10:28 AM
tootie's Avatar
Thank you Elinor, its a pleasure to be here, but i'm having trouble with my "smart key" awww
Old Mar 12, 2018 | 10:48 AM
rhomanski's Avatar
Since you changed both and now both are weak, I'd say it's the batteries sometimes they sit in a shop for a long time. They could have been improperly stored as well. Get a couple from somewhere else and try it.
Old Mar 12, 2018 | 10:55 AM
tootie's Avatar
Hi Rhomanski
I did just that on Sunday afternoon and unless i have been really unlucky by buying weak batteries on two occasions, i have the same fault as in the first place, thank you for your reply.
Old Mar 12, 2018 | 02:52 PM
o1xjr's Avatar
Old Mar 12, 2018 | 03:59 PM
Daf11e's Avatar
Welcome aboard Martin.
Old Mar 12, 2018 | 08:51 PM
rhomanski's Avatar
If you hold it in your hand can you just walk up and open the car? Are you perhaps keeping in someplace that is attenuating the signal? If not it may be a little corrosion on the antenna connection possibly.
Old Mar 13, 2018 | 05:42 AM
Welcome to Jaguar Forums tootie,
rld14
Oct 17, 2017 12:14 PM
digimurda
Mar 21, 2017 08:08 PM
Russell Smith
Sep 1, 2013 07:38 PM
bmgg
Sep 26, 2012 06:43 PM
