Non-Jaguar Vehicles This area is designated for discussion about non-Jaguar Vehicles.
1967 Ford F100 XJR conversion
Old May 2, 2022 | 01:11 AM
david f100's Avatar
Default 1967 Ford F100 XJR conversion
Old May 2, 2022 | 07:22 PM
pdupler's Avatar
Very interesting. We love trucks here in Texas. But that XJR looked perfectly fine. What did the poor Jaguar do to deserve getting its heart ripped out?
Old May 3, 2022 | 12:19 AM
david f100's Avatar
It was a UK MOT failure, needed a lot of welding.
Old May 3, 2022 | 11:23 AM
89 Jacobra's Avatar
Active Streak: 30 Days
That's an interesting swap, I didn't know you Brit's were into trucks???
Jack
Old May 3, 2022 | 12:03 PM
david f100's Avatar
Jack
I didn’t know you Yanks were in to Jags 😂
Old May 3, 2022 | 09:47 PM
89 Jacobra's Avatar
Smart Aleic LOL!
Jack
Old May 16, 2022 | 09:38 AM
clubairth1's Avatar
Community Influencer
How are you going to operate the engine? The electronics are always the hard part.
Old May 16, 2022 | 03:12 PM
david f100's Avatar
I’m aiming to use the OE ECU’s. I’ve removed the whole wiring harness, all the modules, and ECUs.
Before engine removal, I disconnected all the modules i didn’t need and stripped out a bucket full of wiring.
kept checking the motor would run without restricted performance
Now I just need to get it running in the truck !
Old Jun 23, 2022 | 01:01 PM
david f100's Avatar
It runs ! Intercooler is temporary!
Old Jun 23, 2022 | 03:35 PM
89 Jacobra's Avatar
Wow Great Job. Most don't have the fortitude to do a swap of this magnitude.
Jack
Old Aug 14, 2022 | 03:36 AM
david f100's Avatar
Exhaust header fabrication for clearance to the steering box
Old Aug 14, 2022 | 12:03 PM
89 Jacobra's Avatar
Ok, Looks Good but now what do you do with it??? I had a similar issue with the Headers I built for my Jacobra. Sticking a 460 Ford where the v12 used to be wasn't to terrible, but the DS header was quite a challenge.
Jack
Old Aug 14, 2022 | 12:12 PM
david f100's Avatar
Jack
Hi Jack, there’s plenty of space to get the secondary pipes around the back and down under the floor
it was just the cast iron manifold hitting the steering box was the issue
I’ll post some more pictures when I’ve got the rest of the system installed
Old Aug 14, 2022 | 02:41 PM
89 Jacobra's Avatar
Cool, I'm impressed with the work, nice job all the way around.
Jack
Old Aug 16, 2022 | 09:15 PM
DOLPH655's Avatar
Originally Posted by david f100
It was a UK MOT failure, needed a lot of welding. difference between rodents read this article.
Same thoughts right after few fixing my ford f100 is working fine few days 2 chipmunks died come in my way during driving. I was unable to apply break.
Old Aug 19, 2022 | 03:31 PM
david f100's Avatar
A few more exhaust pics
Old Aug 19, 2022 | 08:24 PM
89 Jacobra's Avatar
Wow that came out looking good. Definitely where there is a will, there is a way. Cool!
Jack
Old Aug 20, 2022 | 12:43 AM
david f100's Avatar
Dual dash , checkout the glove box
Old Aug 20, 2022 | 11:11 AM
clubairth1's Avatar
Great work and it's really coming along well!
Do you think the exhaust will cook your steering column rag joint?
It looks kinda close in the pictures.
Old Aug 20, 2022 | 11:54 AM
david f100's Avatar
Thanks !
It’s just the camera angle, there’s at least an 1” clearance to the steering joint, I’m going to wrap the pipes too.
I might mod the inner fenders as that’s the closest part
Sounds awesome !
