Non-Jaguar Vehicles This area is designated for discussion about non-Jaguar Vehicles.
zf6hp26 taking in less fluid
Old May 26, 2018 | 12:25 PM
cheebs's Avatar
Default zf6hp26 taking in less fluid
I joined the forum to get info on the zf6hp26. I have a 06 range rover hse. i have been fixing a few things on it. I did a transmission service where i replaced the pan , fluid and ecu connector. I had to redo the ecu connector as it did not seat right. After the second time replacing the fluid it would not take anymore than 3 Quarts. Someone suggested maybe there air trapped in there. I tried again and could not get it to take anymore than 3 quarts. I followed the transmission fluid check and change to the letter using a thermal gun and alive code scan to check the temp. Any ideas on what might be causing this?
Old May 28, 2018 | 11:23 AM
cheebs's Avatar
Over 200 views and no guesses? Could a stuck solenoid or solenoids hold the extra fluid?
Old May 29, 2018 | 01:36 AM
Robman25's Avatar
First thing to answer is how much fluid came out?
Old May 29, 2018 | 02:24 AM
cheebs's Avatar
the first time about 6 and a half quarts. the second time i did not check . the third time about 3 quarts.
Old May 29, 2018 | 02:57 AM
Robman25's Avatar
So basically you have no idea where you are at. Does the trans have a dip stick?
Old May 29, 2018 | 02:35 PM
cheebs's Avatar
no dip stick. You measure what you have in the tranny but what leaks out after you put the fluid in. Thats why i know something is wrong because it starts to leak out at 3 quarts.
Old May 30, 2018 | 02:15 AM
Robman25's Avatar
Have you tried driving the car since the work has been carried out?
Old May 30, 2018 | 06:11 AM
cheebs's Avatar
I have driven it. 1 and 2 shift badly and so does 3 and 4. i have an error code for the torque converter solenoid. But i am not sure if the solenoid is whats holding the fluid. my understanding is that there should be 10 to 12 quarts and i should be able to drain 6 to 7 quarts. so i am missing 3 or 4 quarts. i believe that the missing quarts are still in the tranny. What i need to figure out is if a solenoid can do that. or if it is something else.
Leedsman
General Tech Help
Mar 22, 2018 04:54 PM
sjagerson
Oct 21, 2017 01:35 PM
comikey
43
Jul 20, 2017 09:22 AM
clubairth1
May 28, 2011 05:02 PM
joycesjag
Mar 6, 2011 11:16 PM
