00 Jag s type
Old Jan 24, 2008 | 12:45 PM
mrhayat's Avatar
Default 00 Jag s type
Hi,
Can anyone advise me, I got this car few months back (80,000km)and it drives lumpy whenI accelerate usually from 80km/hr-120km/hr. I always use 91 Octane fuel,than twice now I had the check engine light flash amber it stays for a day and disappears. The problem is every timeI take it in for a check-up the check engine disappears. Also it emits a horrible sulphuric rotten smell in the cabin.I am wondering if I can get it scanned using an OBD-II scanner first. I filled up at the pump yesterday and used a gas treatment additive & whenI went thru thecar wash yesterday which cleans the undercarriage also and asI drove off I it started jittering, but an hour later it was ok. Any suggestions what this could be?.
Old Jan 24, 2008 | 06:57 PM
FactoryJaguarTech's Avatar
Default RE: 00 Jag s type
Could you please be a little more descriptive with your concern than "lumpy"?
The check engine light...was it blinking then stayed solid?
V8 or V6?
Possibly at catalytic convertor problem.
Give up some more info and I will try to help.
Old Jan 25, 2008 | 09:11 AM
mrhayat's Avatar
Hello,
Thanks for the reply, This is a V6. Yes the amber check enginewas blinkingat first few times than went solid, a day later itwent away again. Sorry what I meant by lumpy is that the car ride is choppy and hesitant , whenshiftingup usually from 80km/hr up to 120. My apologies I just cant find the right word to explain,but it shifts up not smoothly at all and continues tohesitatewhen you give it gas. Its as if not getting enough fuel or air intake. I was thinking it could be the air cabin filter as it emits a rotten smell at times also.Iknow you dont have much to go by specially the way I have worded it. Any suggestions or advise is much appreciated. Also an approximate cost to fix the problem.
Old Jan 25, 2008 | 11:38 AM
Jaguarnaut's Avatar
Hi mrhayat,
Dont apologies, its ok to use those words as thats why we called them Tech guys and not us Just try to delibrate more so Jagtech or other techies can try to solve your problem [sm=signs003.gif]
Old Jan 25, 2008 | 11:52 AM
mrhayat's Avatar
You are definately right. Thanks for the support Jaguarnaut
Old Jan 25, 2008 | 06:29 PM
Well, the rotten smell with the type of hesitation sounds like you have a coil problem. If the Ignition coils cannot make the spark plug fire, the unburned fuel goes into the catalytic convertor and will eventuall give off that smell.
I would also check the breather hoses at the back of the intake. Spray some throttle cleaner down there and see if idle changes. If so, they are leaking.
Pull the silver cover that says Jaguar off from drivers (LHD) side and look at the coils. If they have green or yellow labels on them they are old coils, new ones have black labels on them. If that is the case, I would replace the coils and all the plugs as they are probably fuel soaked.
Hope this helps,
If you need any more direction as to where these items are located. Let us know.
Old Jan 28, 2008 | 02:28 PM
YoungABS's Avatar
What advice FJT do you have on taking the manifold off to replace the other set of coils? I am going to do it myself, but I have not heard of anyone doing so. I am going to replace the whole side since I will have access to change the one bad coil.
Old Jan 28, 2008 | 04:42 PM
If you are going there, do yourself a favour. Get the upper and lower manifold gaskets. Also get the lower breather hose and change it out while you are in there. It is a 13.00 part and stupid to not do it while you have manifold off.
I will post the procedure in the general tech forums later on tonight. It is not hard, but be careful to not overtighten anything or to drop bolts down the intake!
Old Jan 29, 2008 | 10:39 AM
YoungABS's Avatar
Ok. I'll check back later. Thanks!
Old Feb 8, 2008 | 11:10 AM
mrhayat's Avatar
Hi FJT,
Can you also please advise me with this car just recently the engine fan turns on after a 15 min drive, even though the tempraturegauge has always been midway. Also it takes 20 mins or so to get the fan torun the heater warm air.
Old Feb 8, 2008 | 06:52 PM
I would say your expansion tank is leaking. In front of drivers side windshield where you add coolant, this is the tank. They crack pretty consistently.
See if it looks low. If so, fill it up and run the car. see if it starts to leak out underneath drivers side behind front wheel.
Old Feb 11, 2008 | 10:08 AM
mrhayat's Avatar
I will check definately.,Thanks FJT
Old Feb 12, 2008 | 05:16 PM
ausman46's Avatar
I'm intrigued by the 91 Octane fuel rating.
All S-Types delivered in Australia have a 95 Octane sticker on the inside of the filler cap.
The lower octane could cause it to drive "lumpy".
Regards
Old Feb 12, 2008 | 05:27 PM
Different ECM software combats the Octane level. Different parts of the US have different Octane level for premium. Some are 91, some 93 and I have seen a couple that were 95. Wyoming I think?
Anyway, I understand what you are saying, but premium grade fuel is what is recommended. 87 Octane.....now that would be an issue.
You are lucky you get that quality of fuel in Australia. Most of the fuel flaps on Jags in the US have the 91 octane rating.
stanjag
Dec 29, 2024 08:26 PM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
h4wk
Nov 27, 2015 05:10 PM
Numwen
Sep 3, 2015 08:05 PM
pnwrs2000
Aug 28, 2015 09:31 AM
