02 S Type 4.0 stumbles getting up to speed
Old Jan 2, 2020 | 02:00 PM
Rnanc44's Avatar
Default 02 S Type 4.0 stumbles getting up to speed
Hello all, I have an 02 S Type 4.0. No engine codes, starts fine, However she stumbles trying to get up to speed and only wants to reach 3000rpm. Any suggestions would be greatly appreciated.
Also what is CATS Fault??
Old Jan 2, 2020 | 02:08 PM
S-Type Owner's Avatar
Low fuel pressure from the pump, or a partially blocked fuel filter perhaps? You might want to check the fuel pressure at the schrader value on the fuel rail...
CATS is the electronically controlled/dynamic damper system in your car's suspension.
Old Jan 2, 2020 | 03:24 PM
abonano's Avatar
Originally Posted by S-Type Owner
Low fuel pressure from the pump, or a partially blocked fuel filter perhaps? You might want to heck the fuel pressure at the schrader value on the fuel rail...
+1
Old Jan 8, 2020 | 04:39 AM
neilr's Avatar
Damp or failing coils would be one of the the first things I would check. They don't always trigger a fault code.
Old Jan 18, 2020 | 01:58 AM
Rnanc44's Avatar
Default How to fix CATS Fault?
How do i go about fixing the the CATS Fault???
Old Jan 18, 2020 | 11:35 AM
Before taking up the suspension issue, were you able to get your acceleration issue sorted...? If so, what was the solution...?
Old Jan 18, 2020 | 11:42 AM
Rnanc44's Avatar
Default 02 S Type stumbles
After making sure the battery had all its cranking amps and charge I unplugged it and reset the computer. No more codes and sounds great. I’ll take her out later today and see if she’ll perform right. I did replace a filter too so fingers crossed.
still coming up CATS Fault but that’s it. She does ride rough being stuck in track mode. Is there a fuse that might be bad?
Old Jan 19, 2020 | 09:04 AM
JagV8's Avatar
That's cleared the OBD monitors (used for smog tests and proper running), fuel trims, etc.
Look out for P1000 turning to P1111 and if it doesn't soon then you may be in Catch-22 where it can no longer set the monitors in order to flag codes. Hopefully won't happen.
kevpain
Nov 6, 2022 11:11 AM
Eagle180
Mar 19, 2018 02:54 AM
Cerberos
Feb 15, 2017 06:43 PM
fjtrd
Sep 9, 2012 12:03 PM
joeyfroy3
XJ40 ( XJ81 )
Dec 31, 2008 06:39 PM
