03 STR-another replacement parts list
Old Oct 23, 2013 | 02:13 AM
chrisgsemail's Avatar
Default 03 STR-another replacement parts list
So after repairing the rear suspension from the previous owners accident.I tracked down the fuel delivery problem. Now for round 2
So I have the car up on stands draining the trans fluid because of a pan leak. I get the new pan, fluid and misc parts in a couple days. So I have a few problems to track down while the car is on stands.
-A misc knocking sound in the upper intake-after reading a few threads I looked at the torque converter bolts,1 is missing and 2 are loose. So I need to track down some hardware and perhaps some locktite.
-AC makes a horrible grinding sound when turned on. Looks like the motor mounts are failing which has the motor siting lower on the frame-in turn when the AC clutch engages rubs on the frame-
-Transmount is shot as well- I read somewhere that the Thunderbird or Lincoln may have the same transmount?
ABS DSC issues-looks like I need to remove the module for a solder session-
hopefully that is the fix all-
outer tie rods-shot
shock bushings
engine mounts
trans mount
trans pan & fluid
oil &filter
thats just my observation from 10 mins under the car. Im thinking of getting the Auto Enginuity. If you happen to know a cheap part distributor I need them. I want to do some upgrades but need these necessities finished first. Thanks for reading
Old Oct 23, 2013 | 05:16 AM
JagV8's Avatar
Look for Mongoose JLR but use with great care.
Old Oct 23, 2013 | 12:25 PM
GT42R's Avatar
I ordered motor mounts and transmission mount from rockauto recently for 03 STR,
the motor mounts were compatible, but were 1/4-3/8" taller than stock,
The transmission mount was completely incompatible, likely for the 99-02 cars,
Malihide
Apr 11, 2026 02:58 PM
trucknetjack
Sep 13, 2015 09:17 AM
Bcrary3
Aug 31, 2015 11:29 AM
dpappyp
Aug 27, 2015 06:31 AM
Vector
US Lower Atlantic
Aug 26, 2015 05:36 AM
