04 S type 3.0 V Tires 245x50x16 ?
Old Nov 24, 2014 | 11:53 AM
devinda77's Avatar
Default 04 S type 3.0 V Tires 245x50x16 ?
hey guys...do you'll think 245x50x16 tires gonna be too wide for my jag?
Old Nov 24, 2014 | 11:56 AM
tony1963's Avatar
A check engine light bonanza since vehicle speed and rpm won't match expected outcomes.
Old Nov 24, 2014 | 12:03 PM
devinda77's Avatar
for real?? how come ? never heard of it..damn it...it'll look beautiful tho...i had 235/50/17 on my 2000 4.0 s type...so thats why i was just wondering
Old Nov 24, 2014 | 12:41 PM
JagV8's Avatar
Use any of the online tyre size things like Alloy Wheels & Tyres for sale: for Cars, Motorhomes, Vans & 4x4s: Best UK prices with TYRESAVE. Also part-worn tyres
They're only about 2.4% different so I see no problem.
Old Nov 24, 2014 | 01:48 PM
tony1963's Avatar
I'll agree that the overall diameter being within that range probably will not set a code.
Old Nov 24, 2014 | 02:28 PM
Mikey's Avatar
A set of tires larger or smaller in diameter than OEM size will increase speedo error but the vehicle has no idea of it's actual speed over the road so no codes will be set.
Old Nov 24, 2014 | 03:46 PM
tony1963's Avatar
Disagree. The computer sees the vehicle speed and sees the engine RPM along with transmission RPM. Something won't match.
Old Nov 24, 2014 | 04:07 PM
Mikey's Avatar
How does 'the computer' see the vehicle speed? It sees wheel speed and engine speed. Neither is affected by changing tire size.
Old Nov 24, 2014 | 05:05 PM
tony1963's Avatar
The wheel speed is lower with larger diameter tires and that does not compare with the RPM of the engine when the torque converter locks up.
Old Nov 24, 2014 | 05:37 PM
Mikey's Avatar
The relationship between engine rpm and wheel speed does not change according to tire diameter. The vehicle physically obviously travels faster with larger tires, but the car has no way of knowing this.
Speedometers do not measure the actual speed of the vehicles, they are 'wheel tachometers' with a scale analogous to velocity.
Old Nov 24, 2014 | 06:22 PM
JagV8's Avatar
The only way I can see that it could know would be:
1. different sizes front/rear (ouch!) by enough for it to care
2. if it had a sat nav and compared (it doesn't, even when it could)
Old Nov 24, 2014 | 06:38 PM
Mikey's Avatar
Correct on both counts.
Shawn Svacha
Nov 4, 2019 02:47 PM
tonimccloud
Sep 3, 2015 07:58 PM
dcvickers
Sep 2, 2015 06:14 PM
Rusty1952
Sep 1, 2015 05:45 AM
EastFalk
Aug 29, 2015 08:22 PM
