05 4.2 N/A manifold coolant hose leak ... what else to replace
Old May 10, 2012 | 10:11 PM
RRT's Avatar
RRT
Default 05 4.2 N/A manifold coolant hose leak ... what else to replace
Gents,
My wife's 05 4.2 just developed the coolant hose leak under the manifold. While these hoses are replaced, is there anything else easily accessible that ought to be replaced as a practical matter?
Is there a thread on doing this job for a N/A car?
Cheers,
Rob
'84 xj-s 3.6 5 speed getrag
'03 STR
'05 S-Type 4.2
'67 XKE roadster (sold)
'00 XJ8 Vanden Plas (sold)
Old May 11, 2012 | 06:17 AM
bfsgross's Avatar
If the coolant hose leaked then all may be of suspect to leak in the near future. So as a precaution, replace as much that is accessable. Quite a Jag collection ya have there.
Old May 11, 2012 | 10:14 PM
RRT's Avatar
RRT
Thanks. Pulled the manifold today and I'll try to post pics and part nos. for the hose tomorrow. There was just one hose and it circled back into the housing.
As for my wife's 05 and my 03, it's interesting just how different the feel is between the 05 4.2 and 03 STR. It's not the power, it's how the STR planted so differently. Then, the 84 is a lightweight test car with hot engineering cams and she's a sports car not a tourer, and feels closer to an e-type than a v12 xjs. So, they're all fun cars in their own way.
Cheers.
Old May 12, 2012 | 03:57 PM
RRT's Avatar
RRT
Default Pic of coolant hose that blew on wife's 05 4.2
The Jaguar hose part no. was 2W93-9F814-AC. This was the hose under the manifold that blew out.
Cheers.
Attached Thumbnails 05 4.2 N/A manifold coolant hose leak ... what else to replace-photo.jpg
Old May 12, 2012 | 05:18 PM
bfsgross's Avatar
Sounds and looks like you got a handle on the under manifold coolant hose issue. keeping track of nuts and bolts, wire connector, and vaccume lines seem to be the pain the a*&s that most report whilst tackling the job. As you're aware, the STR has an electronic suspension and beefed up hardware.
Old May 12, 2012 | 09:56 PM
RRT's Avatar
RRT
Thanks.
The car's back together and runs better. I'd been throwing a check engine light for random misfires over the winter after short hops. We couldn't find any evident vacuum issues and thought maybe a leaking injector. Also, I thought the car didn't feel right under low rpm loads. When we pulled the manifold it appeared someone had removed the manifold at some earlier time and either didn't change the gaskets or didn't torque the bolts down correctly. We think it wasn't sealing well and worn. We also pulled a lot of connectors and if any that mightn't been connecting well were reconnected properly. At any rate, the car feels and sounds better at low rpms. Cleaned the throttle body a little but I think putting in the new gaskets on a cleaned surfaced has improved the run condition so I'm happy. Also happy my wife had the good sense to not run the car hot when the hose blew.
Cheers.
Old May 13, 2012 | 07:50 AM
bfsgross's Avatar
Props to the wife for not warping the heads, etc. Regarding random misfires: Check cats and coils too. And while inclined, pop in a new fuel filter to boot.
Old May 13, 2012 | 09:05 AM
JagV8's Avatar
See if they come back first - you've probably fixed them
Rutty
XJ40 ( XJ81 )
Jan 10, 2019 09:47 PM
RaceDiagnostics
Dec 11, 2015 10:12 AM
Doug S
Sep 10, 2015 01:53 PM
Doug S
Sep 3, 2015 07:36 PM
Doug S
Sep 3, 2015 05:00 AM
