05 S type 3.0l fuel pump replacement
Old Jan 10, 2020 | 12:46 PM
JRHJR's Avatar
Default 05 S type 3.0l fuel pump replacement
I cannot find a match for my fuel pump after removing it. The 05 has a different fuel pump configuration than previous models. The pump is marked "1 x 4u 9350-AC, 22027 19.26, 0913806458" with no other markings. I have exhaustively searched this forum and the internet but cannot confirm what pump to replace this with although there are a ton of Ford 9350 pumps available. Any thoughts or ideas appreciated.
Old Jan 10, 2020 | 01:15 PM
joycesjag's Avatar
Forum sponsor SNG Barrett. Be sure to have your VIN.
Old Jan 10, 2020 | 01:43 PM
JRHJR's Avatar
Default SNG barrett fuel pump
I appreciate the quick response. I checked the SNG barrett online catalog and unfortunately they only offer assemblies starting at $400 up to $700. I just need the actual pump only. Still looking.
Old Jan 10, 2020 | 03:43 PM
NBCat's Avatar
Have you looked at this listing on eBay:
https://www.ebay.com/itm/For-2002-20...YAAOSwAAJdXmSX
Old Jan 10, 2020 | 04:18 PM
JRHJR's Avatar
Default Not the same pump
The listing indicates it is the right pump for my Jag but the top connection is entirely different. Mine has a green and white plastic fitting with a recessed fitting area for an electrical 2 proong connector. It is integral to the pump and attached with rivets. I guess the pump input/output may be correct but physically it won't work. Thanks for input.
Old Jan 10, 2020 | 05:19 PM
NBCat's Avatar
You may have to broaden your search:
https://www.ebay.com/itm/New-Fuel-Pu...sAAOSwfhNcuiS2
Old Jan 10, 2020 | 07:38 PM
JRHJR's Avatar
Default I think this will work
I have ordered a fuel pump "New AC Delco Fuel Pump 93-08 Jaguar S-Type Vanden Plas XJ8 XJR XJS XK8 X-Type (361283049431)" from Global Automotive on Ebay. It appears to match my old pump. Thanks to all for input. I will update when it is installed.
Old Jan 27, 2020 | 04:53 PM
JRHJR's Avatar
Default Fixed!
Fuel pump as described works just fine. I did have to use the old fuel strainer. The pump provider did not respond to my request for help and I could not find the correct configuration anywhere. Anyway, on the the IMT O ring part replacements. Thanks for all input.
worzella
Sep 2, 2019 10:19 AM
Toybreaker
Nov 17, 2015 03:22 AM
Grog1234
May 10, 2014 07:01 AM
coastaljag98
May 31, 2013 05:32 PM
adesxjr
Jan 2, 2013 10:53 AM
