1999 Rear caliper rebuild advice
Old Aug 11, 2018 | 05:52 PM
lorant.bogath's Avatar
Exclamation 1999 Rear caliper rebuild advice
Hi all,
I am looking for some advice. My rear driver side break seized up so bought a used caliper and decided to attempt rebuilding it (then have it checked by a mechanic, alternatively have my current one rebuilt by a garage).
So what I have done is I used a flathead screwdriver and pried out the piston, the thing is that these are normally need winding in and out. I could manage to pry the piston out 3/4 way then used the handbrake lever on the caliper to move it till it came out. I checked the thread on both sides (caliper and piston) and they were fine. Reassembled the lot and tried the handbrake arm on the caliper, it moved the piston in and out. Now my question is did I ruin anything that I pried out the piston and not unscrewed it? The piston itself is in good nick, no damage on it. Thank you for the help in advance/
managed to pry it out until this point then from here used the handbrake arm on caliper
Old Aug 12, 2018 | 08:55 AM
NBCat's Avatar
What is the MY of your S-Type?
If there are no deep wear marks on the piston, you can certainly reuse it with new seals. You may want to try a wire brush on the outsides of the caliper to remove some of the rust accumulation before reassembly.
Make sure you wind the piston in fully using the correct tools designed for the job. Use the correct brake fluid as well when replacing any of the hydraulic components, which is DOT4 such as Pentosin.
Old Aug 12, 2018 | 11:16 AM
Thank you for your reply
It's a 1999 first production year S-Type. Now I've bought the correct tool and did try if I can wind it back and it went fine. Do you know if I damaged anything when I tried it out? I received yesterday the repair kit, all seals and assembly pastes so looking forward to put the lot together.
Old Aug 12, 2018 | 12:26 PM
NBCat's Avatar
Make sure all the handbrake cable fasteners are seated correctly. It's unlikely you damaged the caliper mechanism.
It's always wise to follow the procedure set forth in the Workshop Manual. If you don't have the Workshop Manual, here is a link to download it:
https://www.dropbox.com/s/jp6343385h...e_FSM.pdf?dl=0
Refer to section 206-04.
Old Aug 12, 2018 | 06:08 PM
Nice, thank you NBCat
I attempted to wind the piston back in and it went all smooth, the small handbrake lever on the caliper moved the piston a couple of mms. What handbrake are you referring to?
kenatofc
Oct 29, 2020 05:02 PM
texasscot
Jul 24, 2017 01:36 PM
Geezer
Oct 17, 2016 06:19 PM
Doug Dooren
Aug 30, 2015 01:40 PM
michaem101
Jun 14, 2010 03:19 AM
