2000 S type 4L Valve cover and plugs
Old Jul 6, 2016 | 10:21 AM
Peter36's Avatar
Default 2000 S type 4L Valve cover and plugs
Hi and HELP! I went to change plugs on noted vehicle and found (pass side) that 3 of the 4 plugs were covered externally in oil??? I take it from pics that the o rings are leaking?? how to fix? and can I do this myself, Vehicle had 94000KM and sits a lot. Thanks to all PEter
Too add fuel to the fire this all started when I checked the codes and found a po3007, indicating that # 7 was misfiring, which plug is # 7?? all I can find is right or left bank??
Old Jul 6, 2016 | 01:08 PM
motorcarman's Avatar
Rock Auto has the VICTOR REINZ VS50397 or FEL-PRO VS50724R. You should be able to find the cam cover gasket set as they are the same as the 3.9 Lincoln LS for your Jaguar X200 4.0.
bob
Old Jul 6, 2016 | 02:11 PM
Peter36's Avatar
Thanks I assume that there are o rings of sort around the plugs?? Thank you Peter
Old Jul 6, 2016 | 08:52 PM
The cam cover 'kits' come with the perimeter gaskets and spark plug well seals.
bob
Larry-Cleveland
Sep 20, 2016 10:02 PM
Hex Type
Jul 4, 2016 12:50 PM
flyrr100
Jul 2, 2016 08:15 AM
scarbro2011
Jul 2, 2016 05:07 AM
BobRoy
Jun 12, 2016 04:04 PM
