2000 s-type window regulator question????
Old Mar 25, 2010 | 06:14 AM
Jon89's Avatar
The earlier S-Types (1999 to 2002) seem to share more parts with the Lincoln LS than the 2003-and-newer S-Types do. There's a guy here on the forum with the screen name Tbird6 who should be able to answer your question. He owns an S-Type as well as an LS. Hopefully he'll read this post and chime in with your answer.
Oh, and once you find out if it works, be sure to update this thread and let everyone know....
Old Mar 25, 2010 | 09:52 AM
tbird6's Avatar
Yes. Purchase it on EBay. Very common problem on both the Lincoln LS and the Jaguar S Type. Only the front door regulators are the same. Also starting in 2003 the parts are different. At least no one has used a LS regulator in the later Jaguar's!!
Old Mar 27, 2010 | 08:47 PM
Gus's Avatar
Gus
This might help http://www.gusglikas.com/AutoRepairSTypeRegulator.htm
Old Mar 27, 2010 | 10:31 PM
Jag2002Driver's Avatar
Originally Posted by drb370
Thanks very much for the info, this will save me some money!!!!
Thanks again
If you find out that you only need a motor, PM me. I changed out a broken right side regulator and kept the motor.
Old Mar 30, 2010 | 09:02 PM
Shibajack's Avatar
It's not hard to put in, just follow the photos and you should be fine. Good Luck!
Old Jul 10, 2010 | 07:24 PM
hendercc's Avatar
Default 2000 S-Type Window Regulator
Thanks Gus. Your pictures helped me replace my right rear window regulator myself and save about $400 vs. having a shop do it. It was $142 for the part including tax and shipping. It probably took me about an hour end-to-end including a search for the duct tape that my kids had used all up (packing tape works fine). It's a little different than doing the front door that you show but close enough. The only challenge was the little plastic pins that hold the window onto the regulator. I managed to tap them out with a punch and not break the window.
Old Jul 10, 2010 | 07:28 PM
hendercc's Avatar
I can also verify that the rear window regulators on the 2000 S-Type do not match the Lincoln LS, according to a local Ford parts dept. and some Google searches.
Old May 27, 2013 | 06:54 AM
mikewv100's Avatar
Default late 2003 s type window regulator
Is there a ford replacement for Serial m51410 late model jag.
I know some ls fir some jags but not sure of year.
Drivers Front
Old May 27, 2013 | 07:27 AM
clubairth1's Avatar
Community Influencer
Well you had your answer above?? No they don't fit.
Old May 27, 2013 | 08:14 AM
Gus's Avatar
Gus
An alternate is not available but rebuilding what you have may be another option see if this helps.
Link Window Regulator USA - The best quality rebuild regulators and repair service! With over 25 years of research and development.
toronadomike
Jan 22, 2026 10:13 PM
99xk8guy
Sep 29, 2025 10:51 PM
Bcrary3
Sep 12, 2021 05:41 AM
GordoCatCar
Jan 2, 2017 01:10 PM
pocketrocket
Sep 3, 2015 07:44 PM
