2000 stype automatic v8
Old Feb 29, 2016 | 12:32 PM
Deeders33's Avatar
Default 2000 stype automatic v8
I'm having issues with my tranny no codes or warning messages was stored for winter. Ran good for 3-5 miles then just lost power still running starts fine gear shifts can feel it go into gear and moves slightly forward or in reverse but wheels don't moves like it's in neutral, had issues with it last summer slipping into neutral twice but just stopped put in park and then back in drive and it was fine.any insight would be helpful thank you! Make it a great day
Old Feb 29, 2016 | 01:44 PM
JagV8's Avatar
Start with the shifter cable first I think. May be stretched, may adjust.
Old Feb 29, 2016 | 02:02 PM
NBCat's Avatar
+1 on checking shifter cable.
Does the gearbox have any external leaks? If so, it may be low on fluid.
The Ford-supplied 5R55N gearbox uses Mercon V fluid, which is readily available. Given the age of the vehicle, it may be best to drain, replace the pan gasket and filter and refill with fresh fluid.
Old Feb 29, 2016 | 08:49 PM
Deeders33's Avatar
Default Thank you
That is what I thought also, thank you for the insight will let you know if that is the case.... Too cold to deal with it had a bit of a heat wave in MN. On Sat. So took it out for a joy ride only to push it back in garage. Praying it's not the tranny!
Warz00
Mar 1, 2016 08:33 AM
XxSlowpokexX
Feb 25, 2016 04:06 PM
albert328gts
Feb 22, 2016 06:29 PM
jcljr166
Feb 8, 2016 09:58 AM
discouragedXK8
Feb 4, 2016 03:13 AM
