2001 3.0 L S-Type sometimes won't start
Old Oct 5, 2008 | 05:27 AM
12RM's Avatar
Default RE: 2001 3.0 L S-Type sometimes won't start
I had one for over 4 years and replaced the lower ball joints, the coolant expansion tank (£80 - LHD ones are cheaper if you drive on the wrong side of the road)), external temperature sensor (£4), all standard faults.
I replaced brakes as well but thats normal on any car. The transmission fluid/filter changed at 60K miles (supposed to be sealed for life ) to hopefully avoid any problems. Sold the car recently and the new owner is delighted with it.
Regarding your problem I would have a look at the gear selector which may be inhibiting you starting the car.
Old Oct 5, 2008 | 09:42 AM
racerx82's Avatar
Check your battery connections.
Old Oct 5, 2008 | 11:37 AM
Indexcrown's Avatar
yes it sounds like loose battery connection. take them off, completely clean the terminals and then put back on tight. also check water in battery.
Old Oct 5, 2008 | 04:17 PM
12RM's Avatar
If the battery is low the instrument needles will do a wee dance when you crank. If nothing happens the fault is elsewhere.
Jumping the car proved it.
Old Oct 5, 2008 | 04:54 PM
12RM's Avatar
I'm not often wrong!
Glad you have an idea of what to look. It may just need some adjustment to the shift, Not had to do that to my old car but Im aware that some have had to.
Enjoy the car.
RM
JarodL
Mar 7, 2024 01:39 AM
Sprayall
May 30, 2021 08:13 AM
Charlene n John
Sep 28, 2015 06:01 AM
Charlene n John
Sep 6, 2015 11:03 AM
Sprayall
Sep 3, 2015 07:49 PM
