2001 s-type fuel pressure spec
Old Jun 10, 2010 | 01:56 PM
Qndskmo's Avatar
Default 2001 s-type fuel pressure spec
I have 2 specs for fuel pressure for a 2001 S-Type V6, one for denso - one for PTEC. No one so far has told me how to tell the difference. Any help would be appreciated. Wallace
Old Jun 10, 2010 | 02:37 PM
JagV8's Avatar
The PTEC is a Denso unit.
What are the specs you have? You know it's a variable pressure?
Er... maybe you could explain what you're really trying to do / wanting to know and why.
Old Jun 11, 2010 | 09:13 AM
Qndskmo's Avatar
I'm trying to address a low power situation and P0171 (lean) code. Fuel pressure at test port is 32-34 PSI scanner reads fuel pressure PID as 265-275 kpa (38-40 psi). Alldata & mitchell show PTEC & Denso systems with 32 and 48 respectively at idle. Supposedly these figures are off the Jag website.
Old Jun 11, 2010 | 10:07 AM
JagV8's Avatar
Not likely to be caused by fuel pressure.
Almost always P0171 is an air leak. What are the fuel trims at idle and at 2500rpm?
Lots of posts on here about the usual faults on that age and type of engine.
Do you have good O2 waveforms for all 4?
toronadomike
Jan 22, 2026 10:13 PM
dsnyder586
Dec 29, 2024 07:39 PM
Sprayall
May 30, 2021 08:13 AM
ccfulton
Sep 20, 2015 05:15 PM
Sprayall
Sep 3, 2015 07:49 PM
