2002 S-Type 3.0 safe mode almost constantly
Old Nov 10, 2020 | 02:12 PM
Dave062's Avatar
Default 2002 S-Type 3.0 safe mode almost constantly
Greetings! The forums helped me through installing new fuel pump for my black cat, now several months later, I have almost daily safe mode warning and can’t figure out what to pursue. Doesn’t seem to be any rhyme or reason but when it’s in safe mode at a stop, the idle is so low that she stalls quite often. Recently investigated battery as cause (tested at 11.6 v off and 13.7v running). Any advise would be appreciated!
Old Nov 10, 2020 | 02:21 PM
NBCat's Avatar
Start with charging the battery for at least five hours at 2 to 5 amps. Use a voltmeter to check the voltage after charging; it should be at least 12.6 volts. If not, replace the battery.
Insufficient voltage can cause random DTCs and instrument cluster warnings.
Old Nov 10, 2020 | 02:40 PM
Dave062's Avatar
thanks! I’ve been reading about the battery causing this but it just seemed too simple to be true.....now if I can only find my charger!
Old Jan 2, 2021 | 08:44 PM
Dave062's Avatar
Default Update on my black cat
Never could find my battery charger (may have got dumped during some garage cleaning), however, it does read 12.6 volts at auto shop. Just failed emissions test today with a p1584 (throttle body) and 2 separate codes for slow response bank sensors. Trying to determine if this cat has reached her 9th life with me or can this still be a battery or connection with TB or similar easy fix. She runs so well when not in safe mode that I just can’t believe she needs massive $$$ poured in! Can we save the Jag?
Old Jan 2, 2021 | 09:20 PM
kr98664's Avatar
Originally Posted by Dave062
Trying to determine if this cat has reached her 9th life...
Step back from the ledge! Don’t jump!
I had the same P1584 code and safe mode with my ‘02 V6. A used throttle body from eBay took care of it. It was about $75 about 5 years ago. A quick search showed several available right now under $150. Piece of cake to change.
Make sure the unit includes the TPS. Some guys sell those separately, but it’s best to get them as a set.
Old Jan 2, 2021 | 11:57 PM
Dave062's Avatar
Thanks for reply! I really envision myself tinkering with this car as long as possible....I’ve been looking at TBs online as well. Not lots of time these days but will update!
thanks again!
wurldfamuz
Aug 9, 2020 07:08 PM
jag_guy_2020
Feb 9, 2020 10:14 AM
davebaileys
Jul 6, 2017 12:09 PM
ManoFlem
Sep 1, 2014 09:11 PM
joec
Dec 22, 2013 08:22 AM
