2002 s-type rear struts
Old Jul 9, 2013 | 09:23 PM
pampurd's Avatar
Default 2002 s-type rear struts
Do I need rear struts or another part? Ride is hard from the rear without a lot of bounce. Also makes dull but noticeable thump sound.
Old Jul 10, 2013 | 12:17 AM
CleverName's Avatar
I'm not familiar with your car, so posting in the forum for your model might get you faster answers. I know some Jags have "air ride" (whatever that is) so again I'm not equipped to be very helpful.
Other questions you will get asked: Are you on factory rims or aftermarket? What tires are you running, and how old are they?
Best of luck,
Vince
Old Jul 10, 2013 | 04:23 AM
pampurd,
I've moved your question from General Tech Help section to S-Type section.
More members with the same model as you will see it here and you should get more replies.
Old Jul 10, 2013 | 05:21 AM
thebiglad's Avatar
What size of wheels and tyres do you have?
Old Jul 10, 2013 | 08:00 AM
pampurd's Avatar
Brand new tires 225/55r/16 on factory rims. Had problem before new tires.
Old Jul 10, 2013 | 01:05 PM
tbird6's Avatar
Have you had a shop take a look? Have you got under the car and looked? It's a pretty complicated independent rear suspension so there are a lot of moving parts.
It could be as simple as changing the tires to a completely worn out suspension. Your car is now over 11 years old.
Have you ever replaced any parts in the rear suspension?
Old Jul 10, 2013 | 06:30 PM
pampurd's Avatar
Rear struts were replaced by dealer at 60k. Rear sway bar replaced last year by Indy shop, but old rear tires did not wear unevenly.
An Indy suspension shop wants $35 to look at it.
Old Jul 11, 2013 | 03:24 AM
thebiglad's Avatar
and what tyre pressures are you running?
bamforp
Aug 14, 2024 05:36 PM
way2far
Aug 31, 2022 09:26 AM
Dicque
Sep 19, 2015 12:53 PM
Numwen
Sep 6, 2015 12:30 AM
02jagstype
Sep 4, 2015 08:20 PM
