2002 s-type transmission problem-=delayed engagement
Old Dec 23, 2011 | 09:45 AM
jodyjackson1's Avatar
Default 2002 s-type transmission problem-=delayed engagement
I have an 02 s-type that has delayed tranny engagement in forward and reverse..it takes a few seconds to go in gear..changed filter and fluid but did not help. Fluid looked nice and clean even before change. Can anyone give me advice on this symptom ...please!!!
Old Dec 23, 2011 | 10:08 AM
JOsworth's Avatar
Have a trans shop drop the valve body out and check it for signs it is starting to go. Normally that issue manifests itself as an issue changing gears, but still good to check. The other thing is have the torque converter checked. A failing one can produce that feeling from the trans.
Old Dec 23, 2011 | 06:45 PM
motorcarman's Avatar
There was info on this fault back in the early 2000s. I think it was an FAQ via EPQR and it was a series of shifts between D,R and N. I don't remember the sequence but I have a print-out of the procedure somewhere.
It did help a little but it is a known fault with the 5R55N gearbox.
bob gauff
aholbro1
Dec 29, 2024 06:46 PM
PlatinumJag
20
Oct 2, 2020 02:23 PM
AtholC
Sep 9, 2015 09:07 PM
Numwen
Sep 6, 2015 12:30 AM
XJsc-guy
Sep 2, 2015 11:43 AM
