2002 STR Brembo discs
Old Mar 23, 2016 | 02:38 AM
rd350ypvs1972's Avatar
Default 2002 STR Brembo discs
Hi, ordered off EBC after entering my reg info a set of discs for the car. On delivery I noticed that the discs are 355mm instead of 365mm. Can these still be used or is it better to return and order the 365mm. The discs when I ordered them didn't have width dimensions and did come under parts that fit my STR
cheers
Old Mar 23, 2016 | 03:03 AM
Cambo's Avatar
No don't even try to fit those discs, they won't work.
Correct parts info for the Brembo STR and X350 are here ==> https://www.jaguarforums.com/forum/s...r-x350-103513/
Old Mar 23, 2016 | 03:54 AM
cheers Cambo, was thinking along them lines
Old Mar 23, 2016 | 09:21 AM
clubairth1's Avatar
Community Influencer
Welcome to the STR world! Very common to get the wrong disc. Those Brembo's are a bit rare!
I only use R1 Concepts rotor's. No cross drilling but I do like and use the slotted ones.
Not bad at about $100 per disc. They are much more expensive other places and don't even try Jaguar!
R1 Concepts Online Shopping - Shop for 2005,Jaguar,S Type.
Old Mar 23, 2016 | 09:57 AM
Mikey's Avatar
cheers
Possibly referring to your car as a '2002 Type R' might cause a problem. There's technically no such thing as the -R did not exist with the pre-facelift cars.
Either '2002.5 Type R' or '2003 Type R' would be more accurate.
Old Mar 23, 2016 | 12:08 PM
thats true mikey, although mine is probably one of the very earliest having being built 10th jan 2002 with a VIN that no one has since it is earlier than the various sites say,it ends with M45183
Old Mar 23, 2016 | 12:35 PM
JagV8's Avatar
Yep, that's early! Some sort of pre-production I think.
You do indeed want the even bigger discs. And suitable pads.
Old Mar 23, 2016 | 02:43 PM
Getting the discs and yellow stuff pads tomorrow for fitting over the weekend
Old Mar 24, 2016 | 02:40 AM
Lspc's Avatar
Hi
What disc's have you gone for?
Regards Lee.
Old Mar 24, 2016 | 04:04 AM
EBC D Series Premium OE Replacement Discs (PAIR) (FRONT) to fit Front__D1602
yellowstuff pads
