2003 Jag S Type R Trans issue
Old Apr 29, 2011 | 07:23 AM
joycesjag's Avatar
Originally Posted by Jpetreeko
When they are going on the gas hard it's getting stuck sometimes in higher rpms instead of shifting. I've been told it may need a new throttle body if the software update does not do the trick.
Any thoughts?
Thinking to myself outloud here:
Being an '03, I would be looking for a slight vacuum leak before I throw alot of money at a hail mary on a TB replacement.
Old Apr 29, 2011 | 08:54 AM
JagV8's Avatar
The high RPM issue does not sound like the trans.
Of course the PCM does that when in Sport.
Otherwise sounds like a problem.
On the 3.0 it would be an air leak. That would be one possible cause on the other engines. Other ideas, anyone?
Old Apr 29, 2011 | 09:53 AM
The Chris X's Avatar
Although this has only happened to me a few times, it only happened when i was going up or down a rather steep grade if i remember right. So maybe it is not related at all. Of course my STR I believe likes to mess with me by turning on the Sport mode all by itself. Maybe I need to drive it faster. Or I am going senile. Either are plausible.
Old Apr 29, 2011 | 11:04 AM
JagV8's Avatar
The Sport thing sounds like a clue. Could be a chafed wire. I'd want to know / fix it.
If it's flipping into Sport it will of course hold onto revs.
Old Apr 29, 2011 | 11:48 AM
joycesjag's Avatar
Our '05, 3.0 does this as well, has been since ownership some 2 + years.
Old Apr 29, 2011 | 12:04 PM
JagV8's Avatar
Er, I'd want to know why!!!
Old Apr 29, 2011 | 12:10 PM
joycesjag's Avatar
I would like to know why the clock switches from 12 HR to 24 HR by itself, more often than sport mode switches.
Old Apr 29, 2011 | 12:22 PM
  #28
JagV8's Avatar
Aha - YOU have the mouse
Being more sensible, that's another thing I'd want to understand.
Old Apr 29, 2011 | 02:22 PM
Leedsman's Avatar
I agree with all about the reliability of the ZF6HP26 transmission; it is reliable, so long as the ATF fluid is replaced at sensible intervals, like 60,000 miles for full-synth. fluid. There has been software control issues, but there has been many changes, you need to be sure you have the latest. My autobox, same as yours, has done 122,000mile and is changing as well as any autobox I've ever driven, AFTER an ATF fluid change with an anti-shudder additive. No jerks, judders, unexplained changes, or hunting. And I really give it the beans once a week -- no probs.
Leedsman.
Old Apr 29, 2011 | 02:35 PM
  #30
I think I'll start a log of occurances to see how often I notice this happening. Taking note of driving conditions and vehicle settings (observable under driving conditions) - it hasn't happened lately but no harm in starting to collect data if it happens again. So far, no codes or any other indicators so I guess it will have to start here.
When I experienced the RPM hold thingy, it wasn't quite the same as how the car holds RPM in the Sport setting, it would hold it (RPM) higher than what the car had previously exhibited as a customary level of sport shifting RPM hold...if that makes any sense. And I don't believe the Sport indicator was lit last time, although that doesn't really rule anything out.
I had the dealer show me the tranny fluid after the gasket replacement and it showed no signs of abnormal wear (25k miles, i'd hope not) - having burned out an X Type tranny I wanted to see it for myself.
May be a computer issue or wire like you said. Very, very, intermittent for me so far.
Old Apr 29, 2011 | 02:40 PM
  #31
Jayt2's Avatar
Veteran: Navy
Active Streak: 30 Days
Battery getting weak ??? Do you have one where you can check the individual cells ??
Old Apr 29, 2011 | 05:08 PM
  #32
I expect it is just the inherant Britishness coming out.
stanjag
Dec 29, 2024 08:26 PM
Mr. Mohr
Nov 27, 2015 08:55 AM
mrplow58
Aug 29, 2015 10:44 PM
Terrance Williams
Aug 26, 2015 11:50 AM
NinoGrimace
Aug 26, 2015 05:15 AM
