2003 s type 3.0 vacuum leak?
Old Aug 7, 2024 | 09:12 PM
Superdad's Avatar
Default 2003 s type 3.0 vacuum leak?
I keep getting code bank 1 is lean. I checked vacuum lines all looks good , ran long fuel trim bank 1 is 19.56 bank 2 is 4.6 at idel. Ive cleaned maf sensor. Checked air box no leaks. I dont know what else to do. It acts likes0 its running great then all of a sudden goes into restricted preformance and runs like crap. I reset and runs great again. Any ideas would help
Old Aug 9, 2024 | 06:24 AM
LalisDanas's Avatar
It could be an intake manifold gasket or a bad O2 sensor on bank 1 that could cause inaccurate readings and throw a lean code.
Old Aug 9, 2024 | 06:36 AM
Superdad's Avatar
Default Yep,
That was my thought im doing that in the morning, 1st see if any intake bolts are loose than spray at base of intake to see if trims change. I guess if nothing there check brake booster.
Old Aug 9, 2024 | 07:58 AM
kr98664's Avatar
Welcome to the forum.
Are you getting code P0171? I ask because some scanners and code readers have generic fault descriptions that are not always accurate. For best results, use the 5 digit code and look up the official Jaguar description here:
JagRepair.com - Jaguar Repair Information Resource
Scroll down to your code (P0171?) and note the list of possible causes:
Engine misfire
Air intake leak between MAF Sensor and cylinder head
Fuel filter / system restriction
Fuel injector restriction
IP Sensor fault (low fuel pressure)
Low fuel pump output
HO2 Sensor(s) (1/1, 1/2) harness wiring condition fault
EFT Sensor fault (low fuel temperature)
MAF Sensor fault (low intake air flow)
Exhaust leak (before catalyst)
ECM receiving incorrect signal from one or more of the following components:
ECT Sensor, MAF Sensor, IAT Sensor, IP Sensor, EFT Sensor, TP Sensor
Here's a good primer on using fuel trims when searching for vacuum leaks. For comparison, what is the other bank reporting?:
2003+ V6 models are prone to damage on the bottom of the resonator on the intake duct. This typically causes a lean condition on both banks, but it is very quick to inspect once you know where to look. See post #32 here:
https://www.jaguarforums.com/forum/s...2/#post1934812
Old Aug 9, 2024 | 11:21 AM
JagV8's Avatar
Does it need new IMT O-rings? But... can they affect only 1 bank? (If your trims are bad for only 1.)
Old Aug 12, 2024 | 02:55 PM
Superdad's Avatar
Default Do you think its possible? Driving me nuts!
Originally Posted by kr98664
Welcome to the forum. On my wifes 2003 s type 3.0 i have been chasing what i thought was a vacuum leak. But have not found one. My fuel trims in bank one keep showing lean. My question is, is it possible a bad cam position switch could cause this? It runs smooth im wondering if its off enough to mess with the mixture. ? Ive checked everything but that.
Are you getting code P0171? I ask because some scanners and code readers have generic fault descriptions that are not always accurate. For best results, use the 5 digit code and look up the official Jaguar description here: no
See what im talking about
Engine misfire
ghjj
Old Aug 13, 2024 | 08:46 AM
JagV8's Avatar
Does that bank 1 large trim drop to near zero when you rev (to about 2500)?
If not, it's not an air leak.
Old Aug 13, 2024 | 09:20 AM
Superdad's Avatar
it does! Exactly when i rev it up to about 2500 it goes almost to zero.i have replaced o2 sensor, pvc valve and checjed every possible leak.
Old Aug 13, 2024 | 10:54 AM
JagV8's Avatar
Somehow you look to have missed the problem.
Your bank 2 is also rather high - does it also drop on revving?
Old Aug 13, 2024 | 01:25 PM
Superdad's Avatar
it wasnt that high until i changed the pcv valve
Ronks2
Jan 19, 2024 03:01 PM
David Missouri
Mar 20, 2023 01:01 PM
Mark Saggese
Oct 21, 2019 01:16 PM
Emmerich
Jan 4, 2019 02:52 PM
baylward
Mar 2, 2015 03:04 PM
