2003 s-type lighting problem
Old Feb 19, 2009 | 08:09 PM
Real_Tech's Avatar
The rear lights are ground switched and not only that they are powered backwards from nearly every other car on the road with power on the outside of the socket. The problem you describe is usually caused by an incorrect bulb being installed. Check ALL bulbs and make sure they are the correct spec for every position. Hopefully no one was dicking around with a test light or worse yet a power probe and sending power backwards to the module drivers and wrecking a $750 module.
D.K
Dec 10, 2023 02:05 AM
Sprayall
May 30, 2021 08:13 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
Sprayall
Sep 3, 2015 07:49 PM
David Thompson
Sep 3, 2015 07:48 PM
