2003 S Type Security
Old Nov 29, 2010 | 09:43 AM
Jaguar45's Avatar
Default 2003 S Type Security
I recently purchased a 2003 s type and the other day my daughter had the car and it wouldnt start. I went over and it looks as though the security system has armed itself. I called a tow company and they came out and checked the battery, it is fine. How do I proceed, take to the dealer to get a new key? Call a lock smith? The current key lets me in but when i try to start it all the gauges go crazy. Thanks in advance for any help.
Old Nov 29, 2010 | 09:54 AM
Gus's Avatar
Gus
I thought if you had the black key not the green key you can insert the key and start the car and this will reset the alarm.
Old Nov 29, 2010 | 10:25 AM
Jaguar45's Avatar
Default yes, true the black key
Thanks for your reply, I do have the black key and still nothing..
Old Nov 30, 2010 | 07:44 AM
JOsworth's Avatar
Thought it was the battery... Nope...
Old Nov 30, 2010 | 07:54 AM
Jaguar45's Avatar
Default Thank you
As a suspected it was the chip in the key, it fell out of the key and the car locked down. I had the chip replaced for immediate use and have ordered a new one. All is good and running just fine!!
Old Nov 30, 2010 | 07:59 AM
JOsworth's Avatar
Ooops... I was wrong....
Where did the chip fall out of??
Old Nov 30, 2010 | 08:44 AM
Gus's Avatar
Gus
The chip in the key would have been the last thing I would have thought of checking. Was this obvious and what was involved in replacing it?
Old Nov 30, 2010 | 10:37 AM
JagV8's Avatar
How can the chip fall out? It's totally enclosed, isn't it?
Old Nov 30, 2010 | 04:13 PM
Yes, please let us have more details about the chip.
Old Dec 2, 2010 | 01:00 PM
Jaguar45's Avatar
The "chip" or technically called the transponder in located in the black part of the key, if you look at it you will see what appears to be a latch but it is glued in. In this case the adhesive material came undone and the chip fell out. I call a high security key replacement company and he knew within seconds what the issue was. Took the key replaced the chip installed the latch and the adhesive and while he was at it he had a high security cutting machine at home in which he made me a new key with transponder and all for under $300.....life saver..
Old Dec 2, 2010 | 01:11 PM
JagV8's Avatar
I had mine apart to change the battery a while back but still am amazed it could fall out. It was awkward to get apart. One of us is lucky or unlucky LOL
Old Dec 2, 2010 | 05:12 PM
Thanks for the explanation.
I thought that only the dealer could prgram the 03 and up keys?
Old Dec 2, 2010 | 05:29 PM
JagV8's Avatar
I think that's mostly true but apparenty Timpsons can do it over here and I guess anyone who's got the right kit plus security authorisation (there's a mechanism in place in the USA, at least) also can. I don't think it's commonplace.
way2far
Aug 31, 2022 09:26 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
David Thompson
Sep 3, 2015 07:48 PM
KarimPA
Sep 3, 2015 07:32 PM
OkieTim
Sep 2, 2015 12:48 PM
