2003 Stype V8 - disengage from paek
Old Jul 4, 2022 | 02:11 PM
lmcqueenl's Avatar
Default 2003 Stype V8 - disengage from paek
The Jaguar has sat idle for many years. Need to wench onto flatbed, but cannot release from park. Engine dies not run, new battery, get transmission/break fault on display panel when turning on to attempt putting in neutral.
Do I need to detach drive shaft or is there a way to disengage the park lever/ put in neutral.
Thx
Old Jul 4, 2022 | 02:28 PM
kr98664's Avatar
Is the lever itself stuck in Park? Or does the lever move but no response from the transmission?
For the lever not moving, here you go:
Old Jul 4, 2022 | 04:04 PM
lmcqueenl's Avatar
Default Disengage from park
Yes, I’ve seen that video and this particular gearshift box has a wire cage belie the cover, and I do not see that lever that is being pushed by a screwdriver .
Old Jul 4, 2022 | 04:08 PM
lmcqueenl's Avatar
Default Stuck lever
As indicated, the lever is stuck. With brake peddle pushed, move lever, it beeps but will not move.
on the aforementioned video, not much help, as the underside of the lever assembly, is not as accessible as that in the video.
jagastruckerhoodornament
Mar 29, 2014 07:31 AM
daboss085
Sep 22, 2012 04:05 PM
gotmoss89
Apr 7, 2011 05:43 PM
ameri180304
Sep 27, 2010 12:22 PM
BugDoc
Aug 5, 2009 10:44 PM
