2004 ignition switch removal
Old Jul 5, 2024 | 07:24 PM
Darrol2004's Avatar
Default 2004 ignition switch removal
Hi everyone
would anyone know how to remove the whole ignition switch
Is there a certain way it needs to be done
Thanking you
Old Sep 15, 2025 | 07:14 PM
nickhand's Avatar
Did you ever find a solution to this problem? I have 2007 S-Type with a bad switch
Old Sep 16, 2025 | 12:37 AM
Darrol2004's Avatar
hi sorry for the late reply
Yes the ignition switch plug at back of ignition lock was faulty
But why I had ignition out i had the ignition barrel tumblers replaced and New keys cut
Fixed the problem
Old Sep 16, 2025 | 05:11 AM
nickhand's Avatar
How did you get the switch out of the panel?
Old Sep 17, 2025 | 03:05 AM
Darrol2004's Avatar
hi sorry for late reply just setling in to new home have moved from new Zealand to united Kingdom for work
the way I removed the ignition was removed the panel below steering column then covers around steering column
I decided to take instermint cluster out so I had a better view
Removed ignition connector from ignition switch
then got a hook tool and used it to pull the retaining clip out
Then ignition came out
pull towards steering column
Hope that helps
Old Sep 17, 2025 | 06:49 PM
scottjh9's Avatar
Take bottom covers off as darrol said. Reach left hand in to back of switch and pull down sharply. Switch will come free of dash. From there you can disconnect electrical plug and cable if desired. There is enough give to pull switch down and to the left to work with it. Dont forget to remove beauty ring around switch also
Old Sep 18, 2025 | 06:45 AM
nickhand's Avatar
Thanks guys that is the info I needed. I'm going to a local pick-a-part salvage yard this weekend. I'll get to practice on a junk car first
Old Sep 30, 2025 | 03:59 PM
nickhand's Avatar
The switch came out as advertised. It was easy to Switch out; but did not fix my problem. I'll start a new thread for that issue
Old Sep 30, 2025 | 04:27 PM
Darrol2004's Avatar
hi glad you figured out how to remove switch
So what is the main issue
Old Oct 1, 2025 | 06:46 AM
nickhand's Avatar
I think I have an issue with the PATS it doesn't seem to recognize the key
tedjan
Oct 30, 2021 02:09 PM
Jose
Feb 23, 2019 05:24 PM
whattrouble
E type ( XK-E )
Jan 16, 2013 03:05 PM
93XJR-S
May 19, 2012 10:43 AM
86JAGVP
Aug 19, 2011 11:45 PM
