2004 S Type ABS/DSC warning light on
Old Sep 19, 2014 | 02:26 AM
Spondon Kev's Avatar
Default 2004 S Type ABS/DSC warning light on
The warning lights are up on my dash board so I decided to check the ABS sensors. All sensors are clean and the wiring is in good condition. I'd read elsewhere that you can continuity test them to get a resistance reading. I've tried this on all 4 sensors but am reading an open line - no resistance. The multimeter is working OK. Could something have happened to take out all 4 sensors or am I testing incorrectly?
Old Sep 19, 2014 | 03:28 AM
JagV8's Avatar
Not much of a test but usually seem to be around 1K ohms.
You can also measure mV and spin the wheel to see a pulse (depends on the meter). A scope would be better!
Old Sep 19, 2014 | 03:38 AM
Hi JagV8, thanks for the response. I've just done a bit more reading on the internet and have found you can get active as well as passive sensors. Active ones have a 12vdc feed to them and can be tested by checking the return voltage when spinning the wheel , passive ones have no voltage and can be resistance tested. I guess mine are active sensors so I'll test for current.
Old Nov 1, 2014 | 09:03 AM
Millharl's Avatar
Have the abs warning ,anti skid ,dsc not available ,.has been diagnosed as rear wheel speed sensor .o.k. But why do I get the engine symbol up as well.
Millharl
Old Nov 1, 2014 | 10:04 AM
JagV8's Avatar
Read codes and see.
X_Type_South_Africa
Dec 9, 2015 05:37 PM
tberry6686
Sep 20, 2015 03:22 PM
Oliver9218
Sep 3, 2015 05:33 PM
EastFalk
Aug 29, 2015 08:22 PM
Aegis21
Aug 27, 2015 08:30 AM
