2004 S Type R transmission cooler lines
Old Apr 11, 2012 | 09:46 PM
FJG123's Avatar
Default 2004 S Type R transmission cooler lines
Hi Everyone(128,000Km on STR)
I had a number of problems with transmission.
1-Tranny takes longer to go into 6th gear on highway.
2-Tranny does the surging at 40-60km/hr
3-When commign toa stop and then accelerating,car feels as though tranny would bang into gear like it slipped.Have to be gentle on gas when starting to take off again.
I went to jag dealer and asked him to look at tranny as I noticed some wetness around cooler lines.I also asked to do the computer updates on transmission.
Mechanic advises me that cooler lines are leaking and seal-connector O-Ring needs to be replaced (I think they mean the sleeve).He indicated that these have all been leaking and may result in low fluid level which maybe causing my problems).He indicates I will need 1 litre of trans oil .I asked whether it made snse to do the pan,filter and transmission oil change at the same time.He felt that was a good idea however,would not result in any savings to me in labour which I thought strange?
Trans lines are $251.28 plus tax
Connector O-Ring seal is $11.70 plus tax
1 liter of trans Oil is $79.95 plus tax
Anyone have any thoughts?
Thanks.Fitz
I also asked about do
Old Apr 12, 2012 | 02:00 AM
JagV8's Avatar
Last part of post cut off. You were saying?
The fluid's much cheaper if you hunt around, though your location may reduce your choice.
A shortage would be very bad for the trans.
If you have it changed/filled make sure it's done properly, checking the trans temp as it's done.
Old Apr 13, 2012 | 09:02 AM
FJG123's Avatar
Default Hello
Sorry it appears I started to say the same thing at the bottom of the post.Please disregard the last sentence of my post.
Does any one know of better pricing on the cooler lines?
It also seems as though it should be cheaper if I don the cooler lines and pan at the same time with labour.
Any thoughts?
Thanks.Fitz
Old Apr 13, 2012 | 01:35 PM
MyBlackCat's Avatar
Any thoughts?
Thanks.Fitz
The cooler lines are dealer only.
What did they quote you for labor to change them? or you doing them yourself.
mine went on my 06 at 40,000 miles, kind of a commonish problem with these cars, happens to a few but enough to make it a common complaint.
Mine looked brand new when they came off but seemed like a production flaw where the rubber meets the steel.
The dealer charged me close to a $1000.00 for parts and labor, it is a bitch of a job and they said even the mechanics hate doing it.
This repair rivals the coolant hose under the supercharger problem for price and frustration to the car owner.
Ext warranty would not cover it due to rubber in the lines.
Old Apr 15, 2012 | 03:18 PM
FJG123's Avatar
Default STR-Coolant lines
Thank you for the responces
The dealer is saying 5.5 hrs =$616 plus $259 for lines and $79. for fluid(1 litre).All told about $1,078 to do this change.
Fitz
Old Apr 16, 2012 | 04:29 PM
04SCat's Avatar
I have the same problem on non-R V8... $1K seems right - I was quoted the same price. The worst thing is - you can't check the fluid level... I had the leak with less than 40K miles...
Old Apr 16, 2012 | 05:07 PM
00gkingr's Avatar
jaguar brought out a adaptive to cure this fault ages ago. on the 2.7 tdv6 the repair is to replace the gear box, oil cooler pipes and the cooler as they suspected coolant was getting into the gearbox oil. for your car the adaptive and a top up of oil should cure the fault. if the pipes are not leaking badly i wouldn't rush to replace them at that cost if there just weeping leave em till they are actually leaking. the wont be a reduction in labour times because they are 2 separate jobs. you don't even have to drain the oil out to replace the cooler pipes. the only thing you have to do that overlaps in the checking of the oil level at the end. (jaguar tech)
Old Apr 17, 2012 | 09:50 AM
JagV8's Avatar
The diesel is a different cooler etc and the only model with that (disastrous) problem. Doesn't affect the OP's car.
stanjag
Dec 29, 2024 08:26 PM
johanasu
Sep 3, 2015 12:39 PM
Aranon
Sep 1, 2015 01:00 PM
EastFalk
Aug 29, 2015 08:22 PM
Aegis21
Aug 27, 2015 08:30 AM
