2004 S Type R transmission fluid change
Old Dec 18, 2011 | 03:31 PM
clubairth1's Avatar
Community Influencer
Congratulations!! You deserve a drink for that!!
Old Dec 18, 2011 | 04:20 PM
JagV8's Avatar
Too right!
Old Dec 23, 2011 | 08:42 PM
sivkov-y's Avatar
I did some searching on a lifeguard 6 fluid substitute and found this post on a different forum. Someone has found a pretty close substitute for the LG6 fluid. Follow the posts to the jackpot.
Cheaper OEM(lifeguard6) 6 speed auto tranny fluid alternative - New 2009 2010 BMW Z4 - ZPOST
Old Dec 24, 2011 | 03:18 AM
JagV8's Avatar
If it was Mercon SP then it's already been discussed here & elsewhere as not being compatible I think.
Old Dec 29, 2011 | 10:50 AM
Doryphoros86's Avatar
I don't know if its been posted anywhere on the forum (I haven't been able to locate a copy), but I found a ZF 6HP26-28 spare parts catalog on the internet.
I don't recall how I found it, but here it is, and hopefully someone will get some use out of it.
File Type: pdf
Old Jan 14, 2012 | 11:02 AM
zetecstr101's Avatar
hey guys whats up have a ? how often or whats the recommended mileage that u do change the trans pan, fluid and sleeve? i have 80000 mile on my str and not sure if it been changed. and also do anyone have so advice on the type of fluid fits for street/strip (but mostly street or daily use once in a blue strip lol) and how would u know if the fluid have the (FM) friction modifier in it?
shawn
Old Jan 14, 2012 | 11:03 AM
btw i look at the link Cheaper OEM(lifeguard6) 6 speed auto tranny fluid alternative - New 2009 2010 BMW Z4 - ZPOST its interesting..
Old Jan 14, 2012 | 11:27 AM
  #28
shawn
Shawn
Have you tried a search or looked in the FAQ's?
Old Jan 14, 2012 | 11:32 AM
Originally Posted by Norri
Shawn
yes i have this threat is the closest i got but need a lil more info..
shawn
Old Jan 14, 2012 | 11:36 AM
  #30
maybe a more direct faq, is there a sticky? im new at this fourm..
shawn
Old Jan 14, 2012 | 11:45 AM
  #31
JagV8's Avatar
It's irrelevant that it's an STR. Same ZF 6HP26 as all other auto S-Types from 2003 (USA).
Lots in the FAQs. To be looking at this thread you've already gone past the FAQs.......
Old Apr 9, 2012 | 02:08 AM
  #32
Blaq Cat's Avatar
I got a buddy of mine that wants to change the ATF in his 06 3.0, but the fluid at the dealer is $75 a liter. Is this life guard stuff the same as the dealers?
Old Apr 9, 2012 | 04:07 AM
  #33
JagV8's Avatar
If possible, don't buy it by the liter. Dealer likely the most expensive (does anyone really not know that???). To save $$$ read previous posts
You'll see same trans is in many cars...
Old Apr 9, 2012 | 05:26 AM
  #34
Languid's Avatar
Originally Posted by Bacardi 151
Perhaps someone can answer this...There used to be a bottle of friction modifer (FM) you could buy from Jag. Without the FM, many owners experienced a "hoot" sound during wide open throttle (WOT)...Jag even put out a TSB about the sound and the FM being the solution...Now Jag discontinued the FM and it's now added to the LG6 fluid. So, the first question is do other tranny fluids contain FMs? Because if they don't, you may have no choice but to use LG6 or to live with the hoot...
They also said use it only once. Do not add it again, so make sure that you do not add it, then later use the upgraded fluid with the friction modifier already in.
Old Apr 9, 2012 | 05:34 AM
  #35
Languid's Avatar
Originally Posted by matty427
I'm looking at mine and the job appears a bit daunting. My S-type has 8 winters on it so I just know that most of those pan bolts are going to snap off. And the drain plug is a hex socket and will undoubtably strip when I try to remove it. Everything is now soaking in "PB Blaster".
1 of the trans. cooling lines has a small leak and requires changing, (another s--- job) so I don't have a choice but to get the plug out to replace the leaked fluid.
Wish me luck guys....
matty,
quick tip: before you try to undo the bolts, give them a sharp rap with a drift & hammer if you think they may be 'tight'. A couple of good 'belts' with a resonable weight of hammer will usually do the trick. Use a drift to avoid missing and directly hitting the pan.
Cheers,
Languid
Old Sep 28, 2013 | 07:04 AM
  #36
anybody got a link for the bolt torque sequence for the trans filter..
Isoruku
Jun 19, 2020 12:54 PM
Rupesh
Mar 25, 2016 03:33 PM
Steve Langridge
Sep 3, 2015 07:35 PM
mrplow58
Aug 29, 2015 10:44 PM
dpappyp
Aug 27, 2015 06:31 AM
