2005 S type no sounds from speakers
Old Feb 19, 2015 | 06:11 PM
Aishaq20's Avatar
Default 2005 S type no sounds from speakers
Hi everyone. My old amplifier went bad and I just bought another one same part number and all, and I still have no sound. I did the am/fm eject test and all I got was main 1.0070. i checked the fuses and all seem to be ok. The 6 disc changer in the back has no power to it but the navigtion unit does. Can anyone help?
Old Feb 20, 2015 | 12:04 AM
Datsports's Avatar
Bugga , I blew my amp a wile back from washing the boot shut and wet it I still had speakers but no subs ! and I replaced it with a slightly diferent part no out of an xj8 , first up it didn't work so I un pluged the fiberoptic plug and re pluged it and away it went ! Also later on I fitted a direct connect bluetooth fm modulated unit (axm-cd-by) buy access mobility to the car witch is a great unit ! witch also meant taking the head unit out , not too hard ! and had a **** of a time getting the fiberoptic plug in the sterio to work again , seems thay are very particular About there connection ! Does sound like you have a power supply issue if one unit is not running ! I no all the remote power supply's are shared from the display unit but as for perment power supply I don't know and wouldn't think that thay are !
Check all fuses in boot in front of Spair weel , and engine bay also the dash ones ! Prety shore there should be two positives at the amp when the sterio is running !
Old Feb 20, 2015 | 04:10 AM
Aishaq20's Avatar
Default checked fuses
I checked the fuses and all are ok. So I started unplugging wires. I unplugged the lead power fiber obtic cable from the distributing connection that connects the amp, and cd changer. I plugged that wire staright into the amp, and I have sound. But no navigation sound. I suspect that it is a case of bad wires that need changing.
way2far
Aug 31, 2022 09:26 AM
SD96XJ6L
Jan 12, 2022 04:30 AM
allenman85
May 10, 2021 03:11 PM
Shawn Svacha
Nov 4, 2019 02:47 PM
dcvickers
Sep 2, 2015 06:14 PM
