2005 V8 System Failure
Old Oct 14, 2012 | 12:10 AM
harmonica2's Avatar
Default 2005 V8 System Failure
Hi Everyone,
I've owned my 2005 V8 for almost a year now, and I really love it.
However, twice I experienced a "system failure" and I am wondering what might be causing it.
In both cases, I was stopped at a stoplight. When I pressed the gas to accelerate, nothing happened. The engine was still idling, and the power steering and breaks still worked. Three error messages were flashing on the console: "System Failure", "Cannot Access CRC", and "Parking Break Failure."
In both cases, I pulled over to the curb at idle speed and used the key to turn off the car. I waited about 15 seconds, started the car, and everything was back to normal.
Thank you for your help,
Ethan
Old Oct 14, 2012 | 04:58 AM
police666's Avatar
sounds like the typical faults associated with a failing battery
Old Oct 14, 2012 | 06:26 AM
joycesjag's Avatar
Typically when the battery starts to fail on these modern S Types many codes pop up. If you do an advanced search "battery" in the "S Type section" you will see.
Old Oct 14, 2012 | 07:51 AM
bfsgross's Avatar
harmonica, ditto to the police666 man...she has either loose battery terminals or a weak battery.
Old Oct 14, 2012 | 08:45 PM
abonano's Avatar
+2 on weak or failing battery - check the date code on the battery - if it's older than 3 years - worth getting a fresh battery installed.
Old Oct 16, 2012 | 03:14 PM
harmonica2's Avatar
Default Thanks!
Thank you for the advice, everyone. I'm having a new battery installed now. I was informed that I had an original battery, so the battery was at least 6 years old, and run about 65,000 miles. I will post again to confirm that the "System Failure" problem is solved.
Old Nov 17, 2012 | 11:35 AM
harmonica2's Avatar
The battery definitely solved the problem. Thanks again for the advice!
Old Nov 17, 2012 | 11:39 AM
bfsgross's Avatar
Excellent! Better than a dealer extracting an exponential amount more money from your piggy bank, huh?
clubairth1
30
Sep 3, 2025 04:38 PM
Moghut
Oct 1, 2015 01:55 AM
MrWhite
Oct 1, 2015 01:43 AM
Zarro
Sep 24, 2015 08:20 PM
laserguy
Sep 3, 2015 02:02 PM
