2006 S type Ignition switch replacement procedure
Old Nov 12, 2018 | 08:13 PM
Paul755's Avatar
Default 2006 S type Ignition switch replacement procedure
I'm hunting down a parasitic current draw on my S-Type, the GEM is not going to sleep. Removing power from the GEM ( remove passenger compartment fuse #33 ) and the car goes to sleep with 20mA quiescent current draw. Scanning the GEMs module data, all the inputs seems to be normal when the car is off. I thought I would try to change the ignition switch as that is a possible cause.
How easy is it to replace the switch portion of the ignition switch ?
Old Nov 13, 2018 | 10:01 AM
S-Type Owner's Avatar
From what I gather, it is the sliding cover piece in the keyway that most often hangs up and keeps the circuit from going to sleep. You might want to try lubricating this part of the lock assembly prior to tackling the job of replacing the entire assembly.
Old Nov 13, 2018 | 06:00 PM
Paul755's Avatar
Thanks, I'll give it a go tomorrow.
Old Apr 28, 2020 | 04:28 PM
M9RC's Avatar
Did you ever fix the fault? I have exactly the same issue, and can only get the battery draw to a normal level by removal of fuse 33. Without removing that, the 4 relays are remaining energised.
Jose
Feb 23, 2019 05:24 PM
Yellow series3
Nov 12, 2018 02:49 PM
Maddan
Aug 11, 2015 12:37 AM
estunum
XJ40 ( XJ81 )
Mar 23, 2009 02:34 PM
