4.2 engine rebuild
Old Oct 26, 2022 | 02:56 AM
Darrol2004's Avatar
Default 4.2 engine rebuild
Hi everyone i have started rebuilding my 4.2 v8 naturally aspirated engine after two valve seats decided they had enough of being attached to cylinder heads
one thing I have found out they are a very expensive engine to rebuild
My question is
I am about to start doing the timing chains and camshafts
but i can not find any timming marks on engine block
I understand timming is set at 45 degrees atdc
but with out any marks how do i tell
I do also have the timming tool kit to lock crankshaft and camshafts in place
Any help would be appreciated
Thanking you
Darrol
Old Oct 26, 2022 | 03:40 AM
JagV8's Avatar
Have you studied both workshop manual & the engine training courses?
Old Oct 26, 2022 | 01:24 PM
xalty's Avatar
there are none they determine the crank cam correlation by just forcing the cams into a known position.
45 degree lock tool then cam flats pointing straight up it’s in the engine repair course 168
Darrol2004
Sep 18, 2022 01:44 PM
Darrol2004
Sep 1, 2022 10:01 AM
car5car
Oct 8, 2018 10:58 AM
stiggy1990
General Tech Help
Nov 7, 2013 08:30 AM
