About to give up....
Old Aug 16, 2011 | 10:06 PM
  #81
jagstr03's Avatar
Originally Posted by xjrguy
Provided that airbox is still intact, it should be good for you. And provided it is off the car pictured, of course. Good find!
Cheers,
Any thoughts on the lean code? Could this be my problem or just coincidental?
Old Aug 16, 2011 | 10:08 PM
  #82
jagstr03's Avatar
Cheers,
Got the box for $150 shipped.
Old Aug 16, 2011 | 11:40 PM
  #83
xjrguy's Avatar
One step at a time. There is a good possibility the airbox will smooth things out some.
Did you see that the cooling system is properly filled and bled??
Cheers,
Old Aug 17, 2011 | 03:44 AM
  #84
JagV8's Avatar
I'm with Steve on this, but any unmetered air can throw a lean code. (But so can such as misfires.)
Old Aug 17, 2011 | 08:11 AM
  #85
joycesjag's Avatar
Just went into restricted performance briefly and code P0171 has shown its ugly digits...
Refer here:
Originally Posted by achysklic
Well after battling these codes (P0171,P0174 with Restricted Performance)for awhile I believe I have finally resolved the issue.
If you have these codes I would try to fix it in this order.
1) Check for air Vac. leaks. This is a common fault....if none found move to next step.
2)Check and clean MAF sensor. This also is a common fault for these codes. If you believe it is the MAF pm me I have 2 extra MAF sensors that I could send you to help you out and save you 70 dollars.
3)Check your air filter. Make sure it is clean and make sure oyur air box has a good seal.
4)Check your gas cap. This believe it or not can cause these pesky codes. Also I have a spare good working gas cap that may help someone if needed.
5) If all the above has checked out ok I am sorry to say it prob. is your Throttle Body. I would check around ebay for a good used one. I found one with 50,000 miles on it like brand new for $90.
So as you can see after I went through all the steps mine ended up being the Throttle Body. I have drove the car for several days with not a hint of P0171 or P0174 with restricted performance.
I hope this helps those with this problem
Old Aug 17, 2011 | 05:00 PM
  #86
jagstr03's Avatar
Originally Posted by joycesjag
Refer here:
I will follow those procedures as well as the coolant procedures and will update when completed. It looks like throttle bodies are going for $300+ on eBay now. As an aside, the RP light is coming on within 2 minutes of driving anywhere now.
Old Aug 18, 2011 | 06:54 AM
  #87
The Chris X's Avatar
Ah, so whatever it is, it is getting more pissed off by the minute. Time to bump this up to Defcon 5 and get this resolved! Keep us in the loop as you make your progressions through the troubleshooting - as you have done so far. Keep the faith, we'll get there!!
Old Aug 18, 2011 | 01:02 PM
  #88
tbird6's Avatar
You can have your TB rebuilt for a reasonable price. It has been posted on this list and they seem to do a pretty good job of it. You do need to wait but you will have the correct part. With Jaguar's it's sometimes difficult to get the correct part because the changes are made based on serial number and not so much by year model.
Old Aug 19, 2011 | 07:20 PM
  #89
jagstr03's Avatar
Just an update; the stock airbox arrived and fixed the rattle/knock, but am still getting the P0171 and P0174 codes and the engine is car is still having major hesitation issues (beginning to think the TC may be going bad as well as whatever is causing the leancodes). Will still be following the checklist provided by achysklic through joycesjag and will update later!
Old Aug 19, 2011 | 11:04 PM
  #90
eds123's Avatar
Did you reset it after the install? Take off both battery connections and touch them together for a few secs and then re-install. That should clear the codes and see if they creep up again now that the knocking has been corrected...
Old Aug 20, 2011 | 01:28 AM
  #91
jagstr03's Avatar
I did not reset through the battery, just cleared the codes with my scanner.
Old Aug 20, 2011 | 03:41 AM
  #92
JagV8's Avatar
You've (hopefully) made a change that means you want it to relearn fuelling. It will do so gradually if you just clear the codes but much faster if you force it to lose its current settings. Easiest way is to diconnect the battery for 5 mins.
Old Aug 25, 2011 | 01:02 AM
  #93
jagstr03's Avatar
While installing the new intake tube (didn't come with the Air Cleaner Box), I noticed that the existing filter had a little oil on it and the MAF seemed to have a little as well. I have not yet been able to make it to the auto store to get cleaner and may just buy another one online and clean the stock one later. I will update afterwards. Thank you everyone for your help thus far!
Old Aug 25, 2011 | 07:00 AM
  #94
What kind of filter - paper cone or cotton gauze (a la K&N) - if I remember right you have some kind of aftermarket intake so I'm assuming the latter. CRC makes a good MAF cleaner - remove it from the intake and clean throughly but make sure you let it dry completely before re-installing and turning the car on. Probably just toss the filter and get a good paper OEM filter, if for anything just to try to eliminate yet another variable.
Oh - wait do you even have the stock intake box still?
Old Aug 25, 2011 | 08:26 AM
  #95
jagstr03's Avatar
Just got the OEM box, that came with the filter from a car with 550 miles, but the stock filter had a little oil on it and the previous cone filter even had a little oil in it.
Old Aug 25, 2011 | 09:00 AM
  #96
Oh i see what you mean. Yeah toss it and grab a new paper one for now.
tomkilner
Oct 9, 2015 07:10 AM
brgjag
Oct 6, 2015 09:27 PM
Spazzzzzzzzzy
XJ40 ( XJ81 )
Oct 5, 2015 04:05 PM
Johnken
Oct 2, 2015 10:12 AM
Glenn Barickman
Oct 1, 2015 04:09 PM
