ABS light
Old Jul 11, 2010 | 11:15 PM
kgrosse's Avatar
Default ABS light
my wife was driving her 2002 S-type when the other day when her ABS activated as she was slowing down to turn into a parking lot. as it happened, she got cut off by another driver and she had to slam on the brakes. when she did, the brakes pulsed rather than grabbed. this was on a hot, dry summer day, so there weren't conditions that should have the ABS activating. the ABS light has been on ever since, but the brakes are working fine. just completed discs and pads about a week prior. any thoughts? taking it to the shop this week for suspension work. would like some thoughts on what he should look at for this issue while he has it.
Old Jul 12, 2010 | 06:21 AM
Gus's Avatar
Gus
You need to read the code.
Old Jul 12, 2010 | 07:47 AM
JagV8's Avatar
The ABS should have codes stored but be aware that an ordinary OBD tool will not read them.
Old Jul 14, 2010 | 08:19 AM
kgrosse's Avatar
thanks. i have a cheap code reader that gets me by in most cases. I'll have my guy check it out while it's in the shop tomorrrow.
Old Aug 7, 2010 | 05:47 PM
kgrosse's Avatar
update. had a bad wheel hub bearing. the lights/codes cleared when the shop did the job.
Old Aug 7, 2010 | 07:07 PM
joycesjag's Avatar
What did the wheel bearing hub install set you back?
Old Aug 8, 2010 | 08:41 AM
JagV8's Avatar
They're less costly than you may expect (over here).
Old Aug 8, 2010 | 09:38 AM
joycesjag's Avatar
John as you remember (maybe) I purchased one from NAPA Auto Parts (stateside) for $250.00ish... it was the wrong one. I had to "dealer" it for our S at nearly $300.00. I changed it out in my bath robe in 20 minutes!
Old Aug 8, 2010 | 09:46 AM
Mikey's Avatar
What were you doing with a bearing in your bathrobe? Is that legal?
Old Aug 8, 2010 | 09:56 AM
JagV8's Avatar
I had just about succeeded in my attempt to forget!!
That's cheap. Not likely to need many in the life of the car lol
Old Aug 9, 2010 | 08:29 PM
kgrosse's Avatar
[quote=joycesjag;232176] I purchased one from NAPA Auto Parts (stateside) for $250.00ish... quote]
Got mine from NAPA for $169 and my buddy (who has his own shop) threw it on for me for $50. Not sure what the regular rate would have been.
Jpav27
Jul 31, 2022 06:43 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
redrover41
23
Sep 25, 2015 01:33 PM
avern1
Sep 8, 2015 06:25 PM
innzane
Sep 2, 2015 10:08 AM
