Abs light after battery change
Old Nov 1, 2012 | 09:59 AM
ajoye5's Avatar
Default Abs light after battery change
Sometime ago I changed the battery on my 2003 STR and immediately got a "parking brake fault" message as well as "ABS" icon. I had my cart checked at the local dealer and was told I needed an electric parking brake motor for $900. Prior to the battery change everything was working properly. Is it likely I really need a parking brake motor or can I clear the codes and correct this issue?
Old Nov 1, 2012 | 10:13 AM
JagV8's Avatar
There may be no codes to clear but you'd need a dealer tool anyway. You may well just need to recalibrate (reset) the EPB which is covered in the HowTos.
Old Nov 1, 2012 | 08:59 PM
Under Pressure's Avatar
Mine did the same after I put in a new battery. I researched a bit on this forum and found the solution. I think to do the EPB reset as JagV8 stated but I can not remember. Try that or other recommendations from here and keep your $900
Old Nov 2, 2012 | 05:55 AM
GT42R's Avatar
EPB reset procedure will clear this up for sure.
JarodL
Mar 7, 2024 01:39 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
Charlene n John
Sep 28, 2015 06:01 AM
OkieTim
Sep 2, 2015 12:48 PM
innzane
Sep 2, 2015 10:08 AM
