Air Bag Problem - Lights On
Old Dec 8, 2024 | 08:40 AM
Richa's Avatar
Default Air Bag Problem - Lights On
Hi Friends,
I have a problem with my air bags light on my 06 STR: it blinks 2 times and repeat for 10 times and stays on.
I Think may be a problem with the drivers seat because it was serviced before the problem
i haven’t found in the forum the code for this problem, can someone please help me ?
I’am from Brazil and my car is in São Paulo and it’s very hard to find information about the car.
Old Dec 8, 2024 | 10:10 AM
motorcarman's Avatar
Info for you.
B2295 RCM Advanced restraint system Side airbag circuit status fault
Flash code 22 – driver side
File Type: pdf
Old Dec 8, 2024 | 10:23 AM
Richa's Avatar
Info for you.
Tks So much !
this could be related to a plug in the drivers seat ?
Old Dec 8, 2024 | 10:34 AM
SRS will set a fault if the key is turned ON with the seat removed or DISCONNECTED.
The MIL should extinguish if the circuit is restored but the DTC will remain logged in the module until cleared.
Check all connections with the YELLOW PLUGS.
Old Dec 8, 2024 | 11:26 AM
Richa's Avatar
Tks for your support !
Johnken
Dec 3, 2021 05:18 PM
xtype62
Jul 25, 2016 02:49 PM
Smooth1Bham
Sep 4, 2015 02:19 PM
rfshafer`
Dec 19, 2014 09:30 AM
Jandreu
Jun 2, 2014 03:32 AM
