Air Bag Light on ?
Old May 29, 2014 | 11:46 PM
Jandreu's Avatar
Default Air Bag Light on ? resolved
OK my air bag light is staying on, will start investigating this weekend but wondered if anyone had some advice?
Old May 30, 2014 | 03:29 AM
smithtrevor's Avatar
1st and most important is DO NOT use a DVM on any air bag circuit with the battery connected, possibly one of the most expensive mistakes you will ever make!!
You need the code from the flashing display when you turn the ignition on, use the search within this forum for "airbag," this will explain how to read the code. When you have the code drop back here, we then have a starting point. TS
Old May 30, 2014 | 04:45 AM
It may just look like a random flashing warning light before it stays on permanently but this is a 'blink' or 'flash' code which helps trace the fault.
Old May 30, 2014 | 05:46 AM
Andy Cox's Avatar
Is this the orange air bag light in front of the passenger seat, which, as I understand it, shows if the air bag is armed or not according to the size / weight of the passenger?
Andy
Old May 30, 2014 | 10:24 AM
Jandreu's Avatar
Searched the archives and found some info.
This is the airbag light in the right instrument cluster.
Mine stays on, never flashes or goes out after turning the key and starting the car.
According to the search info I found the airbag flash codes and info and warnings about connectors and disconnecting the battery, understood.
I also found one thread that mentioned that if the light is steady it is the sensors between the grill and radiator that may have become dislodged/tilted causing the issue.
All was OK three days ago and then my wife used the car for two days while her car was in the shop. When I got in it yesterday the airbag light was on. I asked about it and she thought it was normal and didn't pay it any attention. She did say she scraped a curb on the front while parking. I guess you know where this is going.....
So I 'll check the front sensors this weekend if anyone has more info I'd appreciate it and thanks for your time.
Old May 30, 2014 | 05:03 PM
J, send me a PM with your e-mail address, I have a TSB that will help you and is for your MY. it looks to be either the seat belt buckle or the dvr seat track, hall sensor damaged. TS
Old May 30, 2014 | 06:39 PM
Jandreu's Avatar
PM sent
Old Jun 1, 2014 | 02:11 PM
Jandreu's Avatar
Thanks to smithtrevor sending me info in an email the issue has been resolved. It was the number 10 fuse in the drivers side fuse block. Not sure why it went out and will keep an eye on it but everything is good now.
Old Jun 2, 2014 | 03:32 AM
jamdmyers's Avatar
The airbag electrical connections are notorious for being intermittent. There are a few under the seat, which sits very low to the floor. You have a clue in what you said, your wife drove the car... did she adjust the seat? Did you adjust it back? Happened to me, there are a bunch of writeups on how to diagnose. The fuse may have been secondary to a short in the wiring at some point. Pulling the seat and verifying the connections are sound might be preventative and fairly simple.
Jpav27
Jul 31, 2022 06:43 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
Jeh
XJ40 ( XJ81 )
Oct 13, 2015 09:23 PM
redrover41
23
Sep 25, 2015 01:33 PM
OkieTim
Sep 2, 2015 12:48 PM
