Air con
Old Feb 17, 2013 | 09:26 AM
Mikey's Avatar
Not sure about our S-types, but many cars will not engage the A/C if the ambient temp is below X no matter how the controls are set or what attempts are made to override.
Old Feb 17, 2013 | 09:55 AM
JagV8's Avatar
I bought an accurate enough temp sensor with probe and LCD display for £1.24 inc P&P (under $2) from ebay, new, buy-it-now.
Old Feb 17, 2013 | 10:20 AM
Good advice above, if the shop is confident that the AC is good, you can move on to the other suspects.
Old Feb 17, 2013 | 01:26 PM
darren-talbot's Avatar
Originally Posted by abonano
Sounds to me like you have a small freon leak somewhere in your A/C system (just hope the leak is not in your evaporator core behind the dashboard - and/or your DCCV solenoid(s) could be stuck in the open position (which is a more common issue - and less costly to repair preventing the A/C from adequately cooling the cabin) . I believe the DCCV can be tested by clamping off the feed hoses preventing hot coolant flowing back to the heater core.
First things first - report back with the pressure readings and info requested above - Good Luck!
The schh noise must be a leak behind the dash then. It sound like leaking gas. However surely all the freon would have leaked out by now resulting in no more hiss?
If leak is in core behind the dash. I guess we are talking major money to fix?
Going to call the air con guy tomorrow and get him to check gas pressure etc.
Old Feb 17, 2013 | 05:54 PM
bfsgross's Avatar
Good idea. Keep us posted.
scooternva
29
Mar 25, 2025 12:45 PM
scooternva
19
Oct 27, 2015 02:14 PM
mel
Sep 20, 2015 04:56 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
tonyforman
Sep 10, 2015 07:23 PM
