Air-con (recirculated air button)
Old Aug 31, 2016 | 04:33 AM
Tink's Avatar
Default Air-con (recirculated air button)
The recirculated air button is always off when the car is started ( I can't remember if it should stay in the same position as it is (on/off) when the ignition is turned off). After turning the recirculated air back on when the car is started, it turns itself off again after a period of time, 1min to 5mins or more. Air-con is working fine in fresh/recirculated and heat/cooling modes. Any suggestions as to why it is happening and a possible solution would be appreciated. Tink
Old Aug 31, 2016 | 06:44 AM
JagV8's Avatar
See handbook I think.
Short press - short recirc. Long press (2 beeps) - recirc stays on.
Old Aug 31, 2016 | 09:48 AM
Tink's Avatar
Cheers for that, I will re-read the handbook tomorrow.
Old Aug 31, 2016 | 11:51 AM
aholbro1's Avatar
The "Safety Default" is generally to Fresh Air/Defrost/Hot. So when you turn the car off, thus securing power to the HVAC, the Fresh/Recirc door will move to fresh, distribution flaps to "Defrost" and Temperature mixing flaps to full-hot. The DCCV unpowered state is also to "Hot."
Another general rule is to limit Recirc flap setting to a particular amount of time to limit the amount of humidity in the cabin. I know...seems outdated in an era of nearly 100% a/c fitment...but there is also the "stale air" thing....put a collection of 2-3 humans in a closed space and you soon get "stale air" particularly after a lunch of "Beans-n-brew!"
As JagV8 opined, I believe there are measures you can take to extend the recirc time; you can also punch the button again every time the recirc light extinguishes.
Or...you could fix the oil leak...
Old Aug 31, 2016 | 11:55 AM
Mikey's Avatar
Your car is working as designed. The time is recirc. mode is limited to avoid condensation build up.
Why would you want to defeat/override this?
Old Aug 31, 2016 | 12:15 PM
JagV8's Avatar
Permanent recirc seems not to cause issues. I use it all the time and have for 7 years... (helps avoid the horrible diesel pollution over here)
No condensation problems.
Old Aug 31, 2016 | 04:54 PM
Mikey's Avatar
We have problems here with windows fogging over but that's in temps well below zero.
Old Aug 31, 2016 | 07:47 PM
Tink's Avatar
A couple of responses to the latest posts, I am usually the only person in my 'toy' so stale air/condensation is not an issue. Recirculated is best for cooling efficiency here in Western Australia as the summer days can be very hot. Thanks guys.
Old Aug 31, 2016 | 08:03 PM
Mikey's Avatar
The recirc system will automatically stay on until the car cools to a reasonable temp, then turn itself on and off as required. I've noticed very little efficiency improvement by overriding it during our increasingly frequent spells of 35* temps in the summer.
Old Sep 1, 2016 | 01:04 AM
Tink's Avatar
Thankyou guys, problem solved. JagV8 hint of a longer push on the button to get two beeps has solved this for me. Maybe I'll have to re-read the manual again one day!! :-)
DJS
May 23, 2017 04:37 PM
Rhett
Apr 6, 2016 08:03 AM
coolxj8
Aug 17, 2007 06:12 PM
coolxj8
Jul 29, 2007 12:29 PM
May 15, 2007 03:37 PM
